SKU STH-RBRC-3652
Original price $279.99 USD
Current price $210.99 USD
$210.99 USD - $210.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Nov 13 – Nov 27 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Updated kit, easier to build
  • Binding: Ivory
  • Piezo pickup
  • Neck plate with screws
  • Strap buttons with screws
  • Allen wrenches
  • Set of strings
  • 1/4" instrument cable
Acoustic Electric Hollow Body Double Cutaway Basswood Guitar Kit, Flame Maple Veneer, Piezo Pickup is in stock.
How your electronics connect
