SKU STH-RBRC-3652
Original price $279.99 USD
Current price $210.99 USD
$210.99 USD - $210.99 USD
Updated kit, easier to build
The flame maple top is a thin sheet of real wood, and it is easy to sand through. Keep the sanding light, work by hand rather than with a power sander, and go carefully at the edges where the veneer is thinnest.
  • Binding: Ivory
  • Top Veneer: Flame Maple
  • Scale Length: 648mm / 25.5"
  • Nut Width: 42mm
  • Piezo pickup
  • Neck plate with screws
  • Strap buttons with screws
  • Allen wrenches
  • Set of strings
  • 1/4" instrument cable
Acoustic Electric Hollow Body Double Cutaway Basswood Guitar Kit, Flame Maple Veneer, Piezo Pickup is in stock.
How your electronics connect
