SKU TEH-RBRC-3652
Original price $279.99 USD
Current price $210.99 USD
$210.99 USD - $210.99 USD
Updated kit, easier to build
The flamed maple top is a thin sheet of real wood, and it is easy to sand through. Keep the sanding light, work by hand rather than with a power sander, and go carefully at the edges where the veneer is thinnest.
Beginner-friendly (3/10)
  • Binding: Ivory
  • Top Veneer: Flamed Maple
  • Scale Length: 648mm / 25.5"
  • Nut Width: 42mm
  • Hollow basswood body with flamed maple veneer and ivory binding (unfinished)
  • Piezo pickup
  • Neck plate with screws
  • Strap buttons with screws
  • Allen wrenches
  • Set of strings
  • 1/4" instrument cable
How your electronics connect
