This kit ships with the electronics already terminated. Every part arrives with its lead and
connector fitted, so you plug them together, route the leads inside the body and close the
cover. No iron, no solder.
Everything else about the build is unchanged: you still shape, sand, finish and set up the
guitar yourself.
How your electronics connect
No soldering does not mean no wiring. There is still an order to connect things in, and the
diagram shows every connection in this kit.
See the
wiring diagram for this kit. That is the community thread for this exact layout, so you
can ask about your build there and get an answer against a photo of your own cavity.
Just want the file?
Download
the diagram.
If a connector does not seem to fit, or you are unsure which lead goes where, send us your
order number with a photo of the cavity and we will talk you through it.
