SKU STH-RBRC-3652
Original price $279 USD
Current price $210 USD
$210 USD - $210 USD
Pre-order now and your kit ships free from our U.S. warehouse in about 3 months. Nothing extra to pay at delivery.
  • Secure, encrypted checkout.
Updated kit, easier to build
  • Binding: Ivory
  • Piezo pickup
  • Neck plate with screws
  • Strap buttons with screws
  • Allen wrenches
  • Set of strings
  • 1/4" instrument cable
Acoustic Electric Hollow Body Double Cutaway Basswood Guitar Kit, Flame Maple Veneer, Piezo Pickup is on pre-order.
How your electronics connect
Is the body hollow?
Yes. The body is hollowed out inside and has one soundhole on the top. The top has a thin flamed maple veneer.
