SKU TEH-RBRC-3652
Original price $279 USD
Current price $219 USD
$219 USD - $219 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Nov 18 – Dec 2 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Updated kit, easier to build
  • Sound Holes: 1 oval sound hole
  • Binding: Ivory
  • Controls: Master Volume, 4-Band EQ sliders (Bass, Middle, Treble, Presence)
  • Piezo pickup
  • Neck plate with screws
  • Strap buttons with screws
  • Set of strings
  • 1/4" instrument cable
How your electronics connect
