SKU TEH-RBRC-3652
Original price $279 USD
Current price $219 USD
$219 USD - $219 USD
Updated kit, easier to build
  • Sound Holes: 1 oval sound hole
  • Binding: Ivory
  • Controls: Master Volume, 4-Band EQ sliders (Bass, Middle, Treble, Presence)
  • Piezo pickup
  • Neck plate with screws
  • Strap buttons with screws
  • Set of strings
  • 1/4" instrument cable
Acoustic-Electric Thin Hollow Body Single-Cutaway Guitar Kit, Basswood Body, Flame Maple Veneer, Piezo Pickup is on pre-order.
How your electronics connect
Is the body hollow?
Yes. The body is hollowed out inside and has one soundhole on the top. The top has a thin flamed maple veneer.
