Tak's Tailless Guitar: 7.3 lb and a Shape No Store Sells
If you want to learn to build your own guitar, the fastest way is to do it beside someone who builds them for a living. Guitar Kit World supports in-person build workshops around the world, each one run by an independent luthier in their own shop or makerspace. In Baltimore, Maryland, the workshops are organized and taught by two of them: Ohad Barbibay and Matt Rector.
Ohad Barbibay runs Barbibay Guitars and Pickups in Baltimore. He came into the trade through a 12 hour setup class in early 2016, got hooked in the first hour, and signed up to the Algranati Guitar Making School in Ramat Hasharon, Israel, where he studied building and repair for a year. Two years at a shop in Tel Aviv followed, then five years with Trevor Healy at Healy Guitars in Easthampton, Massachusetts, from 2019 to 2024. He picked up pickup winding during the pandemic, and it grew into its own line. He moved his family to Baltimore in the summer of 2024 and now runs his own shop, doing custom builds, full repair work, and hand wound guitar and bass pickups, including his own signature A90.
That last part is worth pausing on. Most builders buy their electronics in. Ohad winds his by hand, sells them at regional shows, and supplies other working luthiers with them, Kalimar Maia in Fairfax among them. When a student asks why a pickup sounds the way it does, the answer comes from someone who has wound one.
Matt Rector is the luthier behind Rector Guitars and Ukuleles, also based in Baltimore. He is a woodworker and a musician as well as a builder, and he co-hosts the In Tune podcast, which is a useful tell: he is someone who thinks out loud about the craft and the business of making things, not just someone who makes them. He co-teaches every session alongside Ohad.
Two working luthiers in one small class is genuinely hard to find, and it is the best thing about this workshop. Here is how Ohad puts it:
"Whether you want a classic 'T' shape or something totally custom, you'll have two professional luthiers standing over your shoulder to ensure a pro-level result."
A few things happened before the first Baltimore class that tell you more than any bio could.
Ohad insisted the kits arrive as uncut rectangular blanks, with the neck pockets and control cavities pre-routed but the body and headstock outlines untouched. His reasoning was simple: this is a building workshop, so the students should cut their own shapes. In his words, "the uncut perimeter is essential."
When the sample kit arrived, he measured it with calipers, found the neck heel and the pocket did not agree to within a few tenths of a millimetre, and told us the cause was routing tolerance rather than the wood moving. He was right, and our own engineering review confirmed it. He also spotted fret ends proud of the fretboard edge and a split pickup bobbin in the same inspection.
Then, before a single student walked in, he built the whole thing through with his co-instructor so they could pace the teaching properly.
He also ran a free open house first, bringing a finished sample guitar and the raw kits so people could handle both and walk through the curriculum week by week before committing to anything.
Ohad and Matt ran their first Baltimore workshop this spring at the Baltimore Node Hackerspace. It ended the way you want a build class to end: a finished, playable electric guitar going home with the person who built it.
It ran as a dedicated small-group session, so both luthiers were at the bench for every stage. It started with the kit still in the box. From there the work moved to layout, where the neck sits, where the hardware lands, what gets cut away. That is the stage most first-time builders rush and later regret, so it got a pencil, a straightedge, and two sets of eyes. Then the bandsaw, with a luthier calling the cut.
Fretwork came next: frets leveled and crowned with a file, tape masking the fretboard, a straightedge and a sanding block within reach. This is the part that decides whether a guitar plays or buzzes, and it is the hardest thing to learn from a video. Then finish went on the T-style body in a deep purple stain.
Wiring, hardware, then strings, and a final setup, which is where a box of parts becomes an instrument someone actually wants to play.
Images courtesy of Ohad Barbibay and Matt Rector.
"Having a dedicated 2-on-1 setup gave Matt and me the chance to dial in every single step of the process, test our pacing, and figure out how to deliver the best possible hands-on experience at the bench."
They took what they learned from that first run straight back into the program, which is exactly what you want from people who teach the thing they do professionally.
Ohad and Matt ran their second Baltimore class in October with three students. Two finished their guitars within the course, and the third is completing his build after missing the final session.
The bench work was the same as the first class: shaping on the bandsaw, sanding the edges smooth, then finishing. Every body started as a rectangular blank.
This class also brought the first new body shape to Baltimore. One student wanted a single-cut instead of the T-style, so that build started from a blank Junior kit and went into a bright blue stain. A T-style body in the same class got an oil finish that lets the mahogany grain show through.
"Momentum is building nicelyāwe have a solid waitlist and are currently locking in dates for our next workshop."
If you want a seat in the next one, get on that list early through the Baltimore page in our community, linked below.
The workshop runs over four sessions at a makerspace with real tools and real dust. Across the class you work through:
You shape and finish your own solid-body electric, assemble the neck, body, and hardware, wire the electronics, and set the guitar up to play, with Ohad and Matt working alongside you at the bench. Builders in the first Baltimore session went home with a finished, playable instrument.
Ohad and Matt organize these workshops themselves and set the schedule, the class size, and everything that comes with them. Dates for the next one are posted on the Baltimore page in our community, along with anything they add as it gets closer.
See the Next Baltimore Workshop
You can comment there to ask a question, say you are interested, or post progress from your own build once you have started. You can also message @barbibayguitars or @rectorguitars directly on Instagram. Both are working luthiers and they answer their own messages.
Baltimore is one of several cities where an independent luthier runs these workshops, and the list grows when builders ask for it. Tell us where you are on the workshops board. If you would like to host one, or you know a luthier or makerspace in your area who should, say so there too. That is the single fastest way to get a workshop organized in your city.
Browse Workshops and Request Your City
No. The class is built for first-timers and it is guided at every stage by two luthiers. Tell Ohad and Matt your experience level when you get in touch and they will tell you straight whether it fits.
The workshop runs at a makerspace equipped for this kind of work, and the first build used the bandsaw, files, and bench tools on site. Confirm what is provided and what to bring with Ohad and Matt before the class starts.
An electric guitar you shaped, finished, wired, and set up yourself, with two luthiers at the bench with you.
Ohad and Matt set the price, the class size, and what is provided, and they confirm all of it when you register.
Ask as early as you can. Left-handed blank kits are not always in stock and can take several weeks to produce, so it needs arranging well before the class starts.
No. Ohad and Matt own it: registration, payment, scheduling, and everything that happens in the room. We supply the kits and help spread the word.
You do not need a class to start. Every stage above is something you can do at your own bench. For the full shape-it-yourself experience the Baltimore builders got, start with a blank guitar kit and take it from raw wood. To begin with the wiring and setup instead, a beginner kit is the shorter road, and our in-stock kits ship worldwide. Before buying tools you do not need, read which luthier tools actually matter for a kit build.
Near Fairfax, VA instead? Kalimar Maia runs hands-on build workshops at Nova Labs there. Read the Fairfax workshop write-up.
Join 5,000+ guitar kit builders in the Guitar Kit World community. Share your build, ask questions, see builds shared by other community members, and find your next inspiration.
Run a hackerspace, makerspace or teaching shop and want to offer a class like this one? Book a 15-minute call with Nazarine Artis (Naz), who works with our workshop partners. He'll walk you through how a workshop runs, which kits fit your format, and how ordering for a group works.
Book a 15-minute call with Naz ā
Simon S. cut his own body shape from a blank mahogany kit. Then he 3D printed a honeycomb pickguard to fit it and swapped four parts.
Vincent S. had a pale quilted maple top and chose not to stain it. He covered it edge to edge in tattoo-style stickers instead. Here is how he layered, masked and coated it, and what to test before you try it.
