Blank Electric Guitar Kit, Mahogany Body, Mahogany Neck, Ebony Fretboard
SKU BLK-ST-A
$239.99 USD
$239.99 USD - $239.99 USD
Current price $239.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Oct 10 – Oct 17 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
Build a fully custom instrument from the ground up with this double cutaway blank guitar kit, crafted with a solid mahogany body and matching mahogany neck for rich sustain and warm tonal character. The body ships as an uncut rectangular slab, so you draw and cut the outline yourself, while the pickguard and bridge routs are already done. The neck arrives complete, with frets, dot inlays, a fitted nut and a shaped headstock whose six tuner holes are already drilled.
  • Scale Length: 648mm / 25.5″
  • Material: Ebony
  • Controls: 1 Volume, 2 Tone
  • Mahogany body blank, outline not cut, routed for the neck pocket, pickguard and bridge
  • Mahogany neck with ebony fretboard, frets, dot inlays, fitted nut and a shaped headstock with six tuner holes drilled
  • Loaded black pickguard with three single-coil pickups, three knobs and a selector switch
  • Chrome tremolo bridge with six saddles
  • Tremolo sustain block
  • 3x tremolo springs
  • 2x long spring screws
  • Black tremolo cavity cover with six string slots
  • Chrome oval jack plate with output jack fitted
  • Tremolo arm
  • Coiled set of strings
  • String tree with washer
Blank Electric Guitar Kit, Mahogany Body, Mahogany Neck, Ebony Fretboard is on pre-order.
