Heavy Metal Electric Guitar Kit, Mahogany Body, Flame Maple Veneer, Ebony Fretboard, Bolt-On Neck
SKU DB-RMEB-437
Original price $319.99 USD
$319.99 USD
$319.99 USD - $319.99 USD
Current price $319.99 USD
One-peace mahogany wood body kit with beautiful flame maple body top veneer, ebony fretboard and trapezoid pearl white inlays. It's a great choice for DIY guitar builders who are into heavy metal.
  • Flamed Maple veneer is thin and easy to sand through, so use a light touch at the edges
  • Material: Mahogany (1 pc)
  • Top Veneer: Flame Maple
  • Scale Length: 648mm / 25.5"
  • Material: Ebony
  • Shape: Fork Tail, 3+3
  • Nut: Black Locking Nut
  • Bridge: Locking Tremolo
  • Pickguard: Tortoiseshell
  • Guitar body with sharp angular offset-V outline and flame-figured top veneer, routed for two humbuckers and a tremolo (unfinished)
  • Neck with dark fretboard, large block inlays and a black locking nut fitted
  • 2x humbucker pickups with black bobbins in black mounting rings
  • Black double-locking tremolo bridge with black tremolo arm
  • 3x tremolo springs with chrome spring claw and two long mounting screws
  • 3-way toggle switch with black tip, nuts and washers
  • 3x black dome knobs
  • Red pearloid pickguard
  • Red pearloid round jack plate with output jack
  • Black neck plate with four mounting bolts
  • Black rear tremolo cavity cover plate
  • Long black rounded rear control cover plate
  • Coiled string set
  • Assorted black screws
Unfortunately, Heavy Metal Electric Guitar Kit, Mahogany Body, Flame Maple Veneer, Ebony Fretboard, Bolt-On Neck is out of stock.
