Heavy Metal Electric Guitar Kit, Pau Ferro Fretboard, Bolt-On Neck, Locking Tremolo
SKU DB-RBFB-1
Current price $249.99 USD
$249.99 USD - $249.99 USD
Build your own heavy metal style electric guitar with this DIY kit, featuring aggressive styling, powerful humbuckers, and a double locking tremolo system designed for high-performance playing.
  • Scale Length: 648mm / 25.5"
  • Material: Pau Ferro
  • Shape: Fork Tail, 3+3
  • Nut: Black Locking Nut
  • Middle Pickup: None
  • Strings: Steel Machine
  • Guitar body, unfinished, routed for two humbuckers and a recessed tremolo
  • Maple neck with pau ferro fretboard, frets, dot inlays and locking nut fitted
  • Black tremolo arm
  • 3x black dome knobs
  • 4x black string ferrules
  • 2x black strap buttons
  • 3x Allen wrenches
Heavy Metal Electric Guitar Kit, Pau Ferro Fretboard, Bolt-On Neck, Locking Tremolo is in stock.
