Tak's Tailless Guitar: 7.3 lb and a Shape No Store Sells
Wade Evans is a blues player and tattoo artist from Indiana. When our Heavy Metal kit landed on his floor, he skipped paint and picked up a wood-burning pen, freehanding lightning, clouds, flames and a tornado into the bare body. Here is how the build got this far, and what is still to come.
Most heavy metal guitars get their attitude from a can of black paint. Wade Evans gave his a tattoo.
No paint, no stain, no stencil. Just a hot pen, a steady hand and a storm drawn straight onto bare wood. It is one of the most original things anyone has done with one of our kits. And it is not even finished yet.
Wade plays blues, jazz and rock fusion around Indianapolis. If you have been to the Slippery Noodle Inn lately, you may have heard him. Off stage, he works in a tattoo chair. Both jobs show up in this build.
This is not his first kit with us. His first was an E75 hollow body with a spalted maple top. He filmed it from unboxing to fretboard reveal. He named it Beverly June, after his grandmother, who passed away the day the guitar arrived. We told that story in Beverly June: A Guitar, a Grandmother, and a Second Chance.
The Heavy Metal kit is a different animal. It has sharp horns, a forked headstock, two open-coil humbuckers and a double-locking tremolo. Wade's first short with it was a plain unboxing. The paint never came out. Watch the unboxing on his channel.
Wade sat on the floor with the body across his knees and a wood-burning pen in his hand.
There is no stencil in his video. He draws straight onto the bare wood, the way he lays down line work on a client. Lightning bolts crack out from the pickup routes. Clouds stack along the edges. Flames start at the tips of the horns.
Watch him burn the first lines (43 seconds on YouTube).
Wood burning suits a tattoo artist, and it is not forgiving. There is no undo. A slip of the pen stays in the wood, just like a slip of the needle stays in the skin. The shading is built up one dot at a time, the same way stippling works on a client. Look closely and most of the dark tone is thousands of tiny burned dots. That is hours of patient work most builders would never try.
Mark's note: Wood burning has a name, pyrography, and our guide to guitar pyrography covers pens, tips and practice on scrap before you touch a body.
The back is where it all came together. A tornado drops through the middle of the body, around the neck plate and the tremolo cavity. Storm clouds roll off both sides. A small church and a cross sit on the horizon. Smoke swirls near the bottom, and flames lick up both points. He signed it by burning his name into the wood next to the spring cavity.
Wade's own verdict on the back: it turned out fabulous. He is less happy with the front so far. He sanded it and wants more depth, so it is going back for another pass before any finish goes on.
We see a lot of finished kits. Most get paint. Some get stain. A few get a veneer or a custom pickguard. Wade did something different. He did not treat the body as something to cover up. He treated it like skin, with a shape and a grain, and he made the art follow both.
The tornado bends with the curve of the body. The flames run all the way out to the points. The lightning breaks around the pickup routes instead of ignoring them. You only get that when the art is planned around the guitar. That is a tattoo artist's eye, and it shows in every inch of this body.
Wade left a review while the guitar was still bare:
"I think from a perspective of a builder or player, you can customize this and make this anywhere from amateur to professional depends on your skill, knowledge or your wallet, but you can make this and untouchable shred machine."
That is the point of a kit in one sentence. The body above is the same one we sell to anyone. What came off Wade's floor is the only one of its kind.
This guitar is not done, and that is part of why we wanted to tell the story now.
We will update this post when the guitar is finished.
Wade has been building with us for over a year, and every guitar has its own personality:
Follow along on his YouTube channel for the rest of this one.
Wade started with the same Heavy Metal kit anyone can order. Every cavity is routed and the hardware is in the box. We rate it Intermediate, 5 out of 10, mostly for the locking tremolo setup.
See all heavy metal guitar kits
Want to compare first? Browse every electric guitar kit. Not sure where to start? Start here.
What would you burn into a bare body? Tell us in the community.
Yes. Burn the bare, unfinished body before any sealer, grain filler or finish goes on. The pen needs raw wood to mark.
A wood-burning pen, also called a pyrography pen. Fine tips do line work. Wider tips do shading. Practice on scrap wood first.
No. It only darkens the surface of the wood. Go slow near edges and routes, where the wood is thinner and easier to scorch too deep.
Yes. A clear coat protects it. A dye or stain will also darken the light areas, so test it on scrap first. Guitar Finishing 101 covers grain fill, dye and clear.
We rate it Intermediate, 5 out of 10. The neck bolts on and every cavity is cut. The locking tremolo takes the most care to set up.
Yes, but only a few joints. It has two humbuckers, 1 volume, 2 tone and a 3-way switch. Our HH wiring diagram shows that exact layout.
Planning your first build, or turning a bare body into art? Join the Guitar Kit World community to share your build, ask questions and see what other builders are making.
Simon S. cut his own body shape from a blank mahogany kit. Then he 3D printed a honeycomb pickguard to fit it and swapped four parts.
Vincent S. had a pale quilted maple top and chose not to stain it. He covered it edge to edge in tattoo-style stickers instead. Here is how he layered, masked and coated it, and what to test before you try it.
