Far more than just āthe final touchā, the finish of your guitar can not only make or break the appearance of your guitar entirely, it also serves as a last line of defense in protecting the guitar.
Once you pick a finish, check out these guides:
Because the finish plays such a pivotal role, if youāve never finished a guitar before, thereās a lot you really should know, and consider before making a final decision on your choice of finish, including:
- The tonewoods your guitar is made from
- Your skill level and experience
- Your budget
- Your working space and equipment
- The protective qualities of the finish
So, with this in mind, today weāre going to discuss each of these factors in greater detail, but first weāll take a closer look at some popular finishing options kit guitar builders can choose from in the table below.
Keep in mind many of the finishes mentioned below can work in combinations e.g. a solid color + gloss or satin finish or stain finish with gloss clear coats.
The Most Popular Guitar Finishing Types
A. Hand-Rubbed Natural Finish:
Popular with those who appreciate the natural beauty of wood, as it accentuates the natural woodgrain without introducing color.
- Tonewoods:Ā Best for guitars with interesting grain patterns.
- Skill Level:Ā Beginner. A great option if this is your first finishing job.
- Budget:Ā Low
- Workspace:Ā Suitable workbench. Well ventilated area.
- Protective Qualities:Ā Can provide a strong protective layer that guards against daily wear and tear. Depending on product used.
B. Hand-Rubbed Stain Finish:
Accentuates the natural woodgrain while adding color.
- Skill Level:Ā Beginner to intermediate. Requires even applicationĀ which can be affected by openness of woodgrain.
- Budget:Ā Low
- Protective Qualities:Ā Dependent on choice of top coat application for protection.
C. Solid Color Finish:
A uniform color applied across the entire guitar.
- Tonewood:Ā Suits less visually interesting Tonewood e.g.. Basswood.
- Skill Level:Ā Intermediate (requires a steady hand and even application). Lighter colors considered easier. Polyurethane considered easier than Nitrocellulose.
- Budget:Ā Low to moderate (dependent on product chosen).
- Workspace:Ā Well ventilated, dust free area that can handle over spray. Can also be applied outdoors (do not spray on windy days).
- Protective Qualities:Ā Good protection, especially if using automotive paints with 4-5 clear topcoats. Consider 4-5 clear topcoats for better protection.
D. Matte or Satin Finish:
Provides a smooth, non-reflective surface. Tends to be more forgiving e.g. may hide surface flaws.
- Tonewoods:Ā Can be applied over solid color (less interesting woods) or stained finish (more visually interesting Tonewoods).
- Skill Level:Ā Intermediate. Less fine sanding/polishing required compared to gloss finish but requires careful surface preparation.
- Budget: Depends on how it is used e.g. as topcoat or as primary color coat.
- Workspace:Ā Well ventilated, dust free area that can handle over spray .Can also be applied outdoors (do not spray on windy days).
- Protective Qualities: Durable butĀ does not dry as hard as gloss.
E. Gloss Finish:
A high-shine, reflective surface achieved with multiple clear coats.
- Tonewoods:Ā Can be applied over solid color (less interesting woods) or stained finish (more visually interesting tonewoods).
- Skill Level:Ā Intermediate. Requires meticulous surface preparation and fine sanding and buffing.
- Budget:Ā Depends on how it is used e.g. as topcoat or as primary color coat.
- Protective Qualities:Ā Offers a harder protective finish than satin or matte.
F. Burst Finishes e.g. Sunburst:
A gradient finish transitioning from a lighter center to darker edges.
- Tonewoods:Ā Usually semi-transparent and works well on guitar bodies with interesting grain patterns.
- Skill Level:Ā Intermediate to advanced. Requires even application for smooth color transition especially if using spray cans.
- Protective Qualities:Ā Dependent on choice of topcoat application for protection.
G. Metallic Finish:
A finish with metallic flakes that give the guitar a shimmering, reflective quality, often in silver, gold, bronze, or metallic blue.
Ā Ā
- Tonewoods: Suits less visually interesting tonewoods e.g. Basswood.
- Skill Level:Ā Advanced. Requires consistent particle distribution, which prevents uneven coloration and/or a mottled appearance. Requires a high level of surface preparation. Any imperfections will be more visible due to the reflective nature of metallic paints.
- Budget:Ā Moderate to high. Metallic paints are more expensive than standard paints.
- Workspace:Ā Require a highly controlled work space with dust-free conditions to avoid visible imperfections. Solid colors are more forgiving, needing less stringent dust control and preparation, though still important
- Protective Qualities:Ā Dependent on choice of topcoat application for protection. Both metallic and solid colors can provide comparable levels of durability, protection, and resistance to elements.
H. Relic Finish:
Mimics the look of a well-used, aged guitar by distressing the paint and hardware.
- Tonewoods:Ā Effective for various tonewoods, as the focus is on creating an aged look.
- Skill Level:Ā Advanced. Requires an understanding of distressing techniques e.g. dry brushing, sandpaper distressing, applying chemical aging solutions,
- Budget:Ā Moderate; involves additional tools for distressing.
- Workspace:Ā Well ventilated, dust free area.
- Protective Qualities: Usually offers less protection due to intentional wear and tear.
I. Custom Artwork:
Personalized artwork or designs applied using various techniques.
- Tonewoods:Ā Typically Works with any tonewood, as the focus is on the artwork.
- Skill Level:Ā Can be quite advanced; requires artistic skill and experience.
- Budget:Ā Dependent on the complexity and materials used.
- Workspace:Ā Requires a clean, controlled environment for precise work.
- Protective Qualities:Ā Dependent on choice of topcoat application for protection (see gloss or satin finishes).
Finishing Based on Tonewoods
Finishing is essentially a series of choices, and the first decision you need to make involves choosing between a solid color or a transparent finish.
This typically depends on the aesthetic appeal of the wood (and wood grain pattern) used for the guitar body.
Grain Pattern
If the wood has an interesting grain pattern, like a beautiful quilted or flame maple, a transparent or semi-transparent stain finish is a great option as it showcases, and accentuates the wood's natural beauty.
Particularly in the case of quilted maple, using a stain finish can add depth and provide a 3D appearance to the finish (see example below).
Ā
The next image below shows a stained flame maple top. Notice, how it accentuates the striping of the flame maple pattern by providing greater contrast between the light and dark tones.
Ā
If your guitar is made from a less visually interesting wood such as basswood you will be well advised to opt for an opaque finish e.g. a solid color finish.
Donāt get me wrong, basswood is a popular, evenly-balanced tonewood and has been used succesfully in electric guitar construction for many years, but itās fair to say it lacks the distinctive grain pattern of other tonewoods in most cases, and is usually ideal for solid color finishing.
With this in mind, itās common for manufacturers (Ibanez for example) to pair less visually appealing woods with solid color finishes to create a uniform appearance.
Wood Density
When staining your guitar, another consideration to keep in mind is the density of the wood.
Tightly-grained timbers such as maple can be challenging to stain evenly due to their tight grain structure. Wood conditioner or pre-stain sealer can be useful in such cases.
Open-grained timbers can also be difficult to work with when applying a finishing material by hand. Mahogany, for example, tends to absorb stain far more readily than maple, making it difficult to apply stain evenly, which can result in a blotchy look.
Bottom Line: If your guitar lacks an attractive grain pattern consider an opaque finish e.g. solid color spray can finish. Alternatively, if your guitar has an attractive grain pattern consider a transparent or semi-transparent stain finish to highlight and accentuate the natural beauty of the wood. If staining consider the density of the wood and whether you need to use it as a woodconditioner or pre-stain sealer.
Finishing Based on Experience and Skill Level
While it depends on the level of complexity and your artistic skills, if this is your first guitar building project weād recommend against a custom-artwork finish.Ā
While it can seem an appealing idea due to the level of personalization this kind of finish affords you, without prior experience, making custom artwork for wood surfaces, achieving a desirable result can be challenging.
Ā
However, if you are committed to achieving a custom artwork and are new to guitar finishing you could consider using decals or stenciling, and then protecting the artwork under a clear top coat.
You can design your own artwork or find pre-made decals or stickers that fit your style using design software or look online for retailers that offer customization options.
When it comes to stenciling you can purchase pre-made stencils or create your own using stencil paper or plastic sheets.
Bursts, High-Gloss, and Metallic Finishes
Itās all well and good to desire a beautiful sunburst finish after being inspired by the classic looks of a sunburst STĀ®, or instead opt for a high-gloss or metallic finish but if this is your first time finishing a guitar, again, itās going to be difficult.
Ā
Likewise, achieving a mirror-like, high-gloss finish requires careful surface preparation, at least 4-5 layers of clear coat, and careful fine sanding and buffing to avoid imperfections. You can see how this is achieved here:
You should also factor in color selection if opting for a high-gloss finish. If you choose a dark finish e.g. black, this will make it all the more difficult as dark colors tend to show even the slightest imperfections.
Burst finishes on the other hand require a gradual blending of at least two colors (often more), usually graduating from dark to light. To do this well requires a good eye, and a steady hand to create a smooth, even gradient.
Metallic paints, on the other hand, can be difficult to apply well due to the need for consistent particle distribution, which prevents uneven coloration and/or a mottled appearance. Your workspace (ideally, a highly controlled workspace with dust-free conditions) will also need to be considered.
Thatās not to say as a beginner you canāt attempt these types of finishes, but itās best to understand the challenges involved first.
Surface Preparation
If you really want that high-gloss finish, one of the areas you will really need to focus on is surface preparation, and then fine sanding and buffing.
Recommended:Ā Sanding a Guitar Body Prior to Painting
You can read more about that using the links below, but in simple terms your surface preparation is the most important aspect to achieving a flat finish. This is typically achieved by working your way up from a low grit sandpaper e.g. 120 grit and progressing to finer grit paper such as 320- 600 grit, carefully removing the scratch marks left by the coarser preceding sandpaper).
Recommended:Ā Wood Grain Filler for Guitar Bodies
You may also want to sand between coats using 800-1000 grit sandpaper depending on the finishing materials you are using.
Lastly, fine sanding e.g. sanding after applying your finish and finally buffing using an abrasive material e.g. car polish will really help you achieve a mirror-like finish. This is easy enough to learn, but can take a considerable amount of time and elbow grease, especially if working without the benefit of power tools.
Binding
Lastly, if your guitar has binding, you should also consider how you will protect it.
If spray finishing, then the binding will either need to be masked (time-consuming and finicky) or you will need to be prepared to scrape the binding with a razor blade after painting which is also time-consuming and finicky.
This video from Gibson demonstrates how to scrape binding after finishing:
Bottom Line: If you have never finished a guitar before, consider a hand-rubbed oil finish (e.g. Tung Oil or Danish Oil) before tackling more advanced finishes on further projects. They are simple to apply using just a cloth, donāt require spraying or buffing and just happen to look great, as they penetrate the wood and enhance the natural grain.
If you are determined to create custom artwork consider using decals. These can still look highly personalized as decals can be custom ordered. Alternatively, if you really desire an aged look for your guitar, put in the time to investigate and practice (on spare material) wood and paint distressing techniques before attempting this kind of finish on your guitar.
Choosing a Guitar Finish Based on Costs
Simple finishes tend to be the least expensive, in most cases. So, if you are working to a budget, a hand-rubbed stain and/or oil finish is going to be the least expensive option.
But if you want a solid color finish, spray cans can be an affordable option.
Poly Or Nitro?
Water-based polyurethane is usually the best option for beginners due to its ease of application and faster drying time. Itās also a more forgiving finish, allowing a professional result with less experience.
Oil-based polyurethane however requires significantly longer drying time and can be harder to work with in terms of proving even coverage.
If you are chasing a vintage look and have the time (and extra money) nitrocellulose lacquer can provide a great result, but itās better-suited to those with more experience as it it requires more precise application and has a strong odor.
Costs
Iāve finished many guitars using spray cans from my local hardware store. And, while there are a few things to keep in mind (which we have covered here) you can acquire a professional finish for minimal costs, especially if you spray light coats, and maintain a dust-free environment.
In terms of costs, most guitars usually require:
- 2-3 coats of primer (1-2 cans)
- 4-5 coats of color (3 cans)
- 4-5 coats of clear finish (3 cans)
All up you are looking at approx. 7-8 cans which can be purchased for under $10 a can.
Bottom Line: A hand-rubbed oil finish is the least expensive option. In most cases, the guitar will require between 6-8 coats, which a 240ml bottle should allow for with some left over. Costs will vary but most products can be purchased online at Amazon for between $25 and $50. Alternatively, if using spray cans, costs will vary, but you could conceivably do the entire job for around $75.00.
Finishing Based On Workspace and Equipment
The most difficult aspects of spray painting are dealing with overspray, maintaining a dust-free environment, and having space for the guitar to (usually hang) and cure.
You can spray outside, but you are then at the mercy of the weather conditions.
Windy days can be a problem due to particles being blown around and landing on your finish, and of course, you donāt want to be dealing with wet weather on your 2nd or 3rd coat of the day.
Hot days can also be problematic when it comes to paint curing.
Paint that dries too quickly can lead to an uneven application and/or streaks and may also trap solvents underneath, causing the surface to bubble or peel as it cures.
If working indoors and you have a suitable workspace e.g. a garage and intend to spray paint your guitar there are some precautions you should take.
This is predominantly due to safety concerns e.g. the solvents in most spray paints can cause fumes that have the potential to cause respiratory issues or allergic reactions, not to mention most paint products are highly flammable.
Below are a fewprecautions you should take:
- Understand the product you are using. Always read the safety information.
- Ensure the area is well-ventilated e.g. keep a door open or use fans for ventilation.
- Wear a suitable respirator mask, gloves, and eye protection.
- Ensure you have a fire extinguisher and smoke alarms.
- Maintain a clean, dust-free workspace.
- Use drop cloths or plastic sheeting to protect the floor and walls.
Lastly, if spraying and have concerns about particles including dust in the surrounding air getting on your finish, control the airflow as much as possible and consider lightly spraying water (use a fne mist setting) into the surrounding air. This can help settle dust particles, as the water droplets cause the dust to fall to the ground.
Protective Qualities: More than just for looks
A solid color finish with a number of clear top coats offers the best protection against knocks, moisture and general wear and tear from playing.
Ā
Lastly, I want to briefly discuss the protective qualities of your finish and why this should also be considered depending on your circumstances.
Obviously, the finish of your guitar will impact the appearance more than any other aspect of the build but, as mentioned in the introduction, the finish of your guitar is also the last line of defence in protecting your guitar.
The finish of your guitar seals the wood, shielding the guitar from moisture, dirt, oils from your hands, and physical wear, including knocks and bumps, ensuring that your guitar remains structurally sound and in good condition.
If you plan on travelling with your guitar this is something you should keep in mind. If this is the case, I would usually recommend a trip to your local automotive store to look at spray can options.
Gloss or Satin?
Gloss finishes tend to dry harder than satin finishes, so offer better overall protection. Satin or matte finishes usually include flattening agents that can affect the hardness of the finish. Gloss finishes on the other hand include higher levels of solid resins that contribute to hardness and durability.
Bottom line: Automotive paints offer great protection due to their durability and resistance to harsh conditions. Dupli-Color or Rust-Oleum Automotive Enamel are good options, providing a hard, long-lasting finish that can with stand harsh treatment better than most finishing products. Gloss also tends to dry harder than satin or matter finishes.Ā
Final Thoughts
While the finish of your guitar is the most transformative aspect of building a kit guitar, if new to finishing consider more than just the final appearance.
Itās wise to take into account the wood your guitar is constructed from, your experience and skill level, budget and circumstances including your available working space.
Lastly, keep in mind finishing is an art form. It takes time and patience to learn, and relies on great surface preparation, something that takes time to master.
However, itās not rocket science and anyone with the right attitude can learn how to get consistently great finishes. I hope the information above helps you get started.
Your choice of wood matters just as much as the finish itself. Read our guide on which mahogany is best for guitars to understand how different species affect tone and appearance. If you want a top that really shows off your finishing skills, check out our flamed maple guitar kits. For step-by-step help with the full build, visit our guitar kit build guides, or design your custom kit with the exact wood and specs you want.
