After helping more than 5,000 builders complete their instruments, I have a clear picture of what custom guitars actually cost, not just the sticker price, but the total investment including tools, supplies, and finishing materials. Most of our builders spend between 250 and 500 USD all in for their first kit build. Here is how every path to a custom guitar compares.
A custom guitar costs between 200 and 10,000+ USD depending on the path you choose. DIY guitar kits are the most affordable option at 190 to 450 USD, while luthier-built customs run 1,500 to 5,000 USD and brand custom shop instruments start at 3,000 USD. This guide breaks down every path with real numbers so you can decide where your money goes.
A custom guitar is any instrument built or modified to the owner's personal specifications: body shape, tonewood, finish, neck profile, and electronics chosen by the player rather than a factory. Whether you spend 200 USD or 10,000 USD, the result is a one-of-a-kind instrument. The difference is who does the work and how much of the process you control.
The Short Answer: 200 to 10,000+ USD
Four paths lead to a custom guitar. Each one trades off cost, time, skill, and control differently.
DIY Guitar Kit
Typical Cost: 190 to 450 USD (kit only)
Skill Required: Beginner-friendly
Timeline: 15 to 40 hours
Customization Level: High (finish, setup, upgrades)
Parts Build
Typical Cost: 400 to 1,200 USD
Skill Required: Intermediate
Timeline: 20 to 60 hours
Customization Level: Very high (every component chosen)
Luthier-Built
Typical Cost: 1,500 to 5,000 USD
Skill Required: None (luthier does the work)
Timeline: 3 to 12 months
Customization Level: Full (spec every detail)
Brand Custom Shop
Typical Cost: 3,000 to 10,000+ USD
Timeline: 6 to 18 months
Customization Level: High (within brand's options)
This table covers the vast majority of custom guitar builds. Your actual cost depends on material choices, complexity, and how much work you do yourself. Read on for the real numbers behind each path.
DIY Guitar Kits: 190 to 450 USD
A DIY guitar kit is a complete building package containing a pre-shaped body, neck, hardware, pickups, wiring, and step-by-step instructions for assembling a playable guitar at home. This is the fastest and most affordable path to a genuinely custom instrument.
Built by Billy B.
Guitar Kit World offers over 288 kits across every major body style. Here is what real kit pricing looks like in 2026:
S-style kits start at 189.99 USD (basswood body, maple neck, chrome hardware)
T-style kits start at 189.99 USD (basswood or mahogany body options)
Single cutaway kits start at 189.99 USD (bolt-on junior models)
Semi-hollow kits start at 239.99 USD (with f-hole routing)
Custom collection kits range from 399.99 to 449.99 USD (upgraded woods, hardware, and pickup configurations)
Every kit includes the body, neck, tuning machines, bridge, pickups, electronics, all mounting hardware, and an assembly manual. You supply the finish, strings, and basic tools.
What Affects Kit Price?
Four factors drive the price difference between a 190 USD kit and a 450 USD kit.
Body wood. Basswood kits sit at the lower end of the price range. Mahogany and ash kits cost more because the raw materials cost more. A basswood ST-style kit runs 189.99 USD. An ash ST-style kit with pau ferro fretboard runs 199.99 USD. An alder TE-style kit with ebony fretboard runs 219.99 USD.
Hardware quality. Standard chrome hardware keeps the price down. Upgraded hardware, locking tuners, or specialty bridges push kits into the 300 to 450 USD range.
Pickup configuration. Single coil kits are simpler and less expensive. Humbucker configurations, active electronics, or multi-pickup routing add cost. Seven-string kits with specialized pickups run 399.99 to 449.99 USD.
Body complexity. Solid body kits are the simplest to manufacture and the least expensive. Semi-hollow kits with chambered bodies, f-holes, or binding require more precision and cost more. A solid body S-style starts at 189.99 USD. A semi-hollow kit starts at 239.99 USD. A full hollow body with a Venetian cutaway runs 449.99 USD.
Total All-In Cost
The kit price is not the whole picture. Plan for these additional costs:
Basic tools (if you do not already own screwdrivers and a soldering iron): 30 to 80 USD
Realistic total for a first build: 280 to 600 USD, depending on the kit you choose and how elaborate your finish plan is. A basswood ST-style kit at 189.99 USD with a simple oil finish becomes a complete, playable, one-of-a-kind guitar for under 300 USD total.
A parts build means buying each component individually: body from one source, neck from another, pickups from a third, hardware from a fourth. You get maximum control over every single component.
The trade-off is cost and complexity. Buying everything separately eliminates the bundle pricing you get with a kit. A replacement-grade neck alone can run 100 to 300 USD. A quality body blank runs 80 to 250 USD. By the time you add pickups (50 to 200 USD per set), a bridge (30 to 100 USD), tuners (30 to 80 USD), and all the small hardware, you are at 400 to 1,200 USD before finishing supplies.
Parts builds make sense for builders who already know exactly what aftermarket components they want and have the experience to source, fit, and assemble them. If this is your first build, a kit is a better starting point. You can always upgrade your kit with aftermarket pickups or hardware later.
Luthier-Built Custom: 1,500 to 5,000 USD
A luthier is a skilled craftsperson who builds and repairs stringed instruments by hand, typically working from a private workshop. Commissioning a luthier means you specify every detail: scale length, body shape, tonewood, neck profile, finish, pickups, and hardware. The luthier does all the work.
What you get for 1,500 to 5,000 USD:
Expert wood selection and matching
Hand-shaped neck profile to your preferences
Professional-grade finishing (nitro, poly, or specialty finishes)
Full setup and playability optimization
A one-on-one relationship with the builder
What affects the price:
The luthier's reputation and demand (established builders charge more)
Build complexity (multi-scale, extended range, or intricate binding costs more)
Finish work (a hand-rubbed oil finish is faster and less expensive than a high-gloss nitrocellulose finish)
Timeline: Most luthiers have a backlog. Expect 3 to 12 months from deposit to delivery. Some well-known builders have wait lists of 2+ years.
This path makes the most sense for players who want zero hands-on work but full customization, and who value the craftsmanship of a single builder over factory consistency.
Brand Custom Shop Programs: 3,000 to 10,000+ USD
The major guitar manufacturers run custom shop programs where you order a factory-built instrument with your choice of specs. Pricing starts around 3,000 USD for a standard custom order and climbs well past 10,000 USD for artist-spec or limited models.
What you are paying for:
Brand name on the headstock (this is the single biggest cost factor)
Factory consistency and quality control
Resale value (brand customs hold value better than any other path)
Warranty and factory support
What you are giving up:
Time. Wait lists run 6 to 18 months, sometimes longer.
Money. A 5,000 USD custom shop guitar uses materials and hardware comparable to what goes into a 400 USD kit build.
Creative freedom. You choose from the brand's menu of options, not from the full universe of possibilities.
Here is the honest assessment: many players get equal or better playability from a well-built kit or luthier guitar at a fraction of the cost. If the brand name matters to you for collection value or personal preference, a custom shop order makes sense. If your priority is a guitar that plays and sounds exactly how you want it, the other three paths deliver that for less money.
Hidden Costs Most Guides Skip
Every path to a custom guitar carries costs beyond the sticker price. Knowing them up front prevents surprises.
Basic tools (screwdrivers, hex wrenches, soldering iron, wire cutters): 30 to 80 USD if you do not already own them
Setup tools (string action gauge, radius gauge): often included with the kit or available as a phone app
Upgraded pickups or hardware (optional, for builders who want to swap components): 50 to 300 USD
Time investment: 15 to 40 hours spread over a few weekends
For luthier commissions:
Case or gig bag (not always included): 50 to 200 USD
Shipping and insurance if the luthier is not local: 50 to 150 USD
Deposit (typically 30 to 50% upfront, non-refundable)
For custom shop orders:
Case is usually included
Shipping: varies by brand
Options pricing can escalate quickly (figured top, binding, custom inlays)
Which Path Gives You the Best Value?
Value depends on what you want from the experience.
Built by a Guitar Kit World community member.
If you enjoy building things with your hands, a DIY kit is unbeatable. You get a fully custom instrument for under 500 USD total, and you learn how your guitar works from the inside out. Every adjustment and repair becomes something you can do yourself. That knowledge pays dividends for the rest of your playing life. GKW kits start at 179.99 USD, and every kit includes a step-by-step assembly manual. See beginner-friendly kits if you are building for the first time.
If you want a specific brand name on the headstock, a custom shop order is the only option. No kit, parts build, or luthier guitar will carry that branding. You are paying for the name and the resale value that comes with it.
If you want a professional instrument with zero effort on your part, a luthier build is the middle ground. More affordable than a custom shop, more personalized, and built by a single craftsperson who knows your preferences.
If you already know exactly which components you want, a parts build gives you granular control over every piece. Just know that you will pay more for that flexibility compared to a bundled kit.
Guitar Kit World is a US-based retailer specializing in DIY electric and bass guitar kits, offering 288+ kits with step-by-step assembly manuals and expert build support since 2013. If the DIY path appeals to you, browse the full catalog or start with kits under 200 USD for the most budget-friendly entry point.
Yes, building is almost always cheaper. A DIY guitar kit from Guitar Kit World costs 190 to 450 USD. Add 50 to 150 USD for finishing supplies and you have a complete custom guitar for 280 to 600 USD. A comparable factory guitar with similar specs sells for 500 to 1,500 USD, and it will not be customized to your preferences.
How much does it cost to have a luthier build a guitar?
A luthier-built custom guitar typically costs 1,500 to 5,000 USD, depending on the builder's reputation, material choices, and build complexity. Established luthiers with long wait lists charge at the higher end. Newer builders may start around 1,200 to 1,500 USD.
Are cheap guitar kits worth it?
Quality matters more than price. A 190 USD kit with real tonewoods, proper fret installation, and accurate routing will produce a better guitar than a 100 USD kit made from mystery materials with sloppy manufacturing. Look for kits that specify the actual wood species, include all hardware, and come with assembly instructions. GKW kits meet all three criteria at every price point.
What is the cheapest way to get a custom guitar?
A DIY guitar kit is the cheapest path to a genuinely custom instrument. GKW offers kits starting at 179.99 USD. With a simple oil or wipe-on finish (20 to 40 USD in supplies), your total investment can be under 250 USD for a playable, one-of-a-kind guitar.
Can I build a good guitar for under 500 USD?
Yes. Most GKW kit builds come in under 500 USD total, including the kit, finishing supplies, and strings. A basswood S-style or T-style kit at 189.99 USD with a spray-can lacquer finish (about 30 to 50 USD in materials) produces a solid, great-sounding instrument for around 250 to 300 USD all in. The quality of the finished guitar depends more on your patience during finishing and setup than on how much you spend.
An acoustic-style bridge glues to the top and its position is permanent. Here is what the part is, the three ways it anchors strings, and how to fit each one on a kit build.
Bill Antonitis had never carved wood when he bought a chisel set from Home Depot, printed a stencil, and cut a rune into the top of his first guitar kit. He also turned spent shotgun shells into control knobs, dropped magnet-mounted LEDs into the f-holes, and found out mid-build that a semi-hollow has no control cavity.
