Why Build a DIY Guitar Kit Instead of Buying a Guitar?
Building a DIY guitar kit instead of buying a ready-made guitar gives you a fully custom instrument for 280 to 600 USD total, teaches you how guitars work from the inside out, and produces a one-of-a-kind instrument that no store sells. The trade-off is 15 to 40 hours of your time and the patience to learn finishing and assembly. For most hands-on people, that trade-off is worth it.
A DIY guitar kit is a complete building package containing a pre-shaped body, neck, hardware, pickups, electronics, and assembly instructions. You supply the finish, strings, and basic tools. The result is a playable electric guitar built to your specifications. Guitar Kit World has shipped kits to builders in over 100 countries since 2013, with 288+ kits across 40+ body shapes starting at 179.99 USD.
DIY Kit vs Ready-Made Guitar: The Direct Comparison
DIY Guitar Kit
Cost: 280 to 600 USD total (kit + finishing supplies + strings)
Time to play: 15 to 40 hours of building over 1 to 4 weekends
Customization: Full control over finish, hardware color, pickup upgrades, headstock shape
Uniqueness: One of a kind, no two kit builds are alike
Skills gained: Soldering, finishing, setup, guitar construction knowledge
Future maintenance: You can do your own setups, repairs, and upgrades
Ready-Made Guitar (500 to 1,500 USD range)
Cost: 500 to 1,500 USD for comparable quality and features
Time to play: Immediate, ready out of the box
Customization: None, factory standard finish, hardware, and setup
Uniqueness: One of thousands from the same production line
Skills gained: None
Future maintenance: Requires a guitar tech for setups and repairs (50 to 100 USD per visit)
A factory guitar gets you playing faster. A kit build gets you a better understanding of your instrument, a custom finish, and long-term self-sufficiency for maintenance and upgrades. The question is which matters more to you.
5 Reasons to Build a Kit Instead of Buying
1. Cost savings on a genuinely custom instrument. A GKW kit at 189.99 USD plus 50 to 150 USD in finishing supplies produces a complete guitar for under 400 USD. A factory guitar with comparable wood, pickups, and hardware costs 500 to 1,500 USD, and it is not customized. For the price of one mid-range factory guitar, you could build two kit guitars in different styles.
2. Complete creative freedom over the finish. Factory guitars come in 3 to 5 standard colors. A kit build gives you unlimited options: oil finishes that show natural wood grain, spray-can sunbursts, epoxy art, hand-painted designs, or vinyl wraps. The finish is the most visible and personal part of any guitar, and kits give you total control over it. See Guitar Finishing 101 for step-by-step instructions.
3. You learn how guitars actually work. When you solder pickups, adjust the truss rod, set intonation, and wire the controls yourself, you understand what every component does. That knowledge pays dividends for the rest of your playing life. Every setup adjustment, string change, and hardware swap becomes something you can handle yourself instead of paying a tech.
4. Upgradeable platform for future improvements. A kit guitar is designed to be modified. Swap pickups, change tuning machines, install a new bridge, experiment with different wiring configurations. Because you assembled it, you know exactly how to take it apart and improve it. See Can I Upgrade My DIY Guitar Kit? for upgrade ideas.
5. The building experience itself has value. Kit building is a hands-on creative project that combines woodworking, electronics, and art. Many builders describe it as meditative and deeply satisfying. The finished guitar carries meaning that a store purchase cannot replicate: you made it with your own hands.
When Buying Ready-Made Makes More Sense
A kit is not the right choice for everyone. Buy a ready-made guitar if:
  • You need to play immediately and have no time for a building project
  • You have no interest in hands-on work or finishing
  • Brand name and resale value matter more than customization
  • You want a specific model that is not available as a kit
For players who fall into both camps, there is a middle path: build a kit as a second guitar or backup instrument while keeping your factory guitar as a daily player. Many GKW builders started this way and now have multiple kit builds alongside their store-bought guitars.
Who Builds DIY Guitar Kits?
Some builders would rather not start alone. If that is you, independent luthiers run hands-on guitar building workshops in a growing list of cities, where you build a full instrument at the bench with a working luthier beside you.
Kit building attracts a wider audience than most people expect:
  • First-time builders, beginner-friendly kits include step-by-step manuals and require only basic tools
  • Experienced players, build a backup guitar, experiment with new body styles or pickup configurations
  • Woodworkers and hobbyists, a guitar is a satisfying project that produces a functional instrument
  • Gift givers, a DIY kit is a creative, personal, and memorable present
  • Parents and kids, a weekend building project that teaches STEM skills through music
  • Educators, GKW supports STEM guitar programs for schools and workshops
Is it cheaper to build a guitar from a kit or buy one?
Yes, a kit build is almost always cheaper. A GKW kit at 189.99 USD plus finishing supplies totals 280 to 400 USD for a complete guitar. A factory guitar with similar specs (same wood, pickups, hardware quality) costs 500 to 1,500 USD. The price difference is labor: you do the assembly and finishing work yourself.
How long does it take to build a guitar from a kit?
Active building time is 15 to 40 hours depending on the kit and your finish approach. A simple oil finish can be completed in a weekend. A spray-paint finish with multiple coats and wet sanding extends the project to 2 to 4 weeks because of drying time between coats.
Do I need woodworking experience to build a guitar kit?
No. GKW kits come with pre-shaped bodies and necks, pre-drilled holes, and step-by-step assembly manuals. The most challenging steps are soldering the electronics (learnable in 30 minutes) and applying a finish (patience matters more than skill). Every kit includes a build difficulty score so you can choose confidently.
Are DIY guitar kits any good?
Quality varies by manufacturer. GKW kits use real tonewoods (basswood, mahogany, ash, alder), include quality hardware and pickups, and come with detailed assembly manuals. A carefully built and properly set-up kit guitar is functionally comparable to a mid-range factory guitar at a fraction of the cost. See the customer gallery for real builds from the community.
To see the kits builders rate highest, browse our high quality guitar kits, every in-stock kit rated 4.5 stars or higher.
Can I build a guitar kit as a gift?
Yes, guitar kits are one of the most popular gift items at GKW. A kit is a creative, educational, and deeply personal present. Some gift givers build the kit themselves and present the finished guitar; others give the kit as an unbuilt project. Either approach works.
Guitar Kit World is a US-based retailer offering 288+ DIY guitar kits across 40+ body shapes, with free worldwide shipping and step-by-step assembly manuals since 2013. Browse the full catalog to find your first build.
For a full cost comparison across all paths to a custom guitar, see How Much Does a Custom Guitar Cost?
Related Products
Original price $229 USD
Current price $199 USD
$199 USD - $199 USD
Skill 8/10 Advanced
Build your own double cutaway guitar with this blank body DIY kit, made for builders who want to cut the shape themselves. The body ships as an unc...
Double-Cutaway Contoured Electric Guitar Kit, Ash Body, Pau Ferro Fretboard, Black Hardware
Original price $239 USD
$199 USD - $199 USD
Skill 2/10 Beginner
Start your dream guitar build with this ash ST-style kit, complete with Pau Ferro fretboard maple neck for a beautiful finish. Perfect for aspiring...
Original price $269 USD
Current price $219 USD
$219 USD - $219 USD
Skill 9/10 Advanced
