SKU TEH-RSAB-3689
Original price $279.99 USD
Current price $244.99 USD
$244.99 USD - $244.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Nov 12 – Nov 26 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Material: Ash
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Binding: Single, Black
  • Bridge: Hardtail
  • 2x black dome knobs
  • 1x black barrel switch tip
  • 2x strap buttons
