Spalted Maple Top Double-Cutaway Electric Guitar Kit, Black Body Binding, Skunk-Stripe Maple Neck, Pearl White Pickguard, Humbucker Bridge Pickup
SKU ST-RMBC-5667
Original price $289 USD
Current price $239 USD
$239 USD - $239 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Nov 9 – Nov 16 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
Six details you rarely find together on a double-cutaway kit: a spalted maple top, black body binding, a skunk-stripe maple neck, a pearl white pickguard, a humbucker in the bridge and a reverse headstock.
  • Spalted maple top. Spalting is the dark, ink-like line pattern that forms naturally in maple. No two tops match, so the figure on your kit will differ from the one in the photos.
  • Black body binding. A black strip is already fitted around the top edge, so the spalted pattern arrives framed and ready for your finish.
  • Skunk-stripe maple neck. A dark stripe runs down the back of the maple neck, where the truss rod was installed from behind.
  • Pearl white pickguard. It comes already fitted with the pickups, a volume control, two tone controls and a 5-way switch.
  • Humbucker in the bridge. Most double-cutaway kits carry three single-coil pickups. This one puts a humbucker, a double-coil pickup, in the bridge position, next to two single-coils.
  • Reverse headstock. The tuners run along the opposite edge of the headstock from most double-cutaway kits, with a pointed tip.
The rest of the kit: a solid mahogany body, an ebonized fretboard with white dot inlays, a bone nut, a six-screw tremolo bridge and chrome hardware.
  • The spalted maple veneer is the one step that needs care: it is thin and easy to sand through, so use a light touch, especially near the bound edge
  • Everything else is pre-shaped and pre-routed, the neck bolts on, and the pickups, pots and switch come mounted on the pickguard
  • Follow our step-by-step assembly manual and wiring guide written for this type of kit
  • Binding: Single Black (around the top edge)
  • Top: Spalted maple veneer
  • Side Dots: White
  • Shape: Reverse 6-in-line (as in product images)
  • Bridge: Six-screw tremolo
  • Pickguard: Pearl White
  • Knobs: White
  • Cavity Covers: White
  • Mahogany guitar body with spalted maple top and black binding (unfinished), pickguard already fitted
  • Maple guitar neck with skunk stripe, dark fretboard and white dot inlays
  • White pearl pickguard fitted with one white humbucker, two white single-coil pickups, three white knobs and a 5-way blade switch
  • 6x chrome sealed tuners
  • 6x chrome tuner bushings
  • 6x chrome washers
  • Set of guitar strings
  • Chrome six-saddle tremolo bridge with 6x mounting screws
  • Chrome tremolo arm
  • 3x tremolo springs
  • Chrome spring claw with 2x mounting screws
  • White tremolo cavity cover plate
  • Chrome neck plate
  • 4x neck mounting screws
  • Chrome boat-shaped output jack cup with output jack
  • 2x chrome strap buttons with felt washers
See the same kit with an ash body and flame maple top in the flame maple double-cutaway kit, or browse the full range of double-cutaway guitar kits.
Spalted Maple Top Double-Cutaway Electric Guitar Kit, Black Body Binding, Skunk-Stripe Maple Neck, Pearl White Pickguard, Humbucker Bridge Pickup is in stock.
What is a spalted maple top?
Spalting is a natural pattern of dark, ink-like lines that forms in maple wood. On this kit a thin sheet of spalted maple is glued over the mahogany body and framed with black binding, so the figure on your kit will differ from the one in the photos.
It brings together six details you rarely find on one double-cutaway kit: a spalted maple top, black body binding, a skunk-stripe maple neck, a pearl white pickguard, a humbucker in the bridge and a reverse headstock. For a flame maple top on an ash body, see the flame maple double-cutaway kit; for a plain mahogany body, see the mahogany kit with a roasted maple neck.
We rate it Intermediate, 5 out of 10. The body and neck are pre-shaped and pre-routed, the neck bolts on and the pickups, pots and switch come mounted on the pickguard. The one step that needs care is sanding the thin spalted maple veneer. Our step-by-step assembly manual walks you through the build, and here is how we score build difficulty.
It is right-handed, with a 648 mm (25.5") scale and 22 frets. The headstock is reversed, so the tuners sit along the lower edge of the headstock when you hold the guitar to play.
