SKU TEH-RSAB-3689
Original price $279 USD
Current price $244 USD
$244 USD - $244 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Dec 2 – Dec 16 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Material: Ash
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Binding: Single, Black
  • Bridge: Hardtail
  • 2x black dome knobs
  • 1x black barrel switch tip
  • 2x strap buttons
It has a fixed bridge plate with three saddles. The bridge pickup is mounted inside this plate. There is no tremolo arm.
Is the body hollow or solid?
Is the top solid spalted maple?
No. The top is a thin spalted maple veneer glued onto the body. Sand it lightly so you do not sand through it.
