Hollow Body Archtop Electric Guitar Kit, Mahogany Body, Gold Hardware, Ebonized Fretboard
SKU E175-RMEG-3
Original price $319 USD
Current price $309 USD
$309 USD - $309 USD
Pre-order now and your kit ships free in about 6 months.
A fully hollow archtop kit in plain mahogany, with gold hardware and abalone pearloid inlays. The body is laminated mahogany with two f-holes, a single Florentine-style cutaway and multi-ply black binding. There is no veneer on the top, so the mahogany grain is the face of the guitar and there is no thin veneer layer to sand through. The mahogany neck is set in: it fits a pocket in the body and is glued in place, with no neck screws.
The ebonized fretboard has 22 medium jumbo stainless steel frets, a 14" radius and abalone pearloid trapezoid inlays on a 24.75" scale, and the neck is bound in black. Two humbuckers run through two volume and two tone controls and a 3-way toggle switch. An adjustable bridge on two posts and a gold trapeze tailpiece carry the strings, and six sealed gold tuners and a bone nut finish the headstock. The body and neck arrive unfinished, ready for the stain or paint you choose.
  • Multi-ply binding must be masked carefully when finishing
  • Cutaway: Single Florentine Style
  • Binding: Multi-ply Black
  • Binding: Single Black
  • Width at 5th Fret: 46 mm
  • Width at 9th Fret: 49 mm
  • Width at 12th Fret: 52 mm
  • Width at 22nd Fret: 56 mm
  • Shape: Classic Blues, 3+3
  • Controls: 2 Volume, 2 Tone, 3 Way Switch
  • Knobs: Gold
  • Finish: Gold
  • Hollow archtop guitar body with two f-holes and bound edges, unfinished
  • Guitar neck with dark fretboard and abalone pearloid block inlays
  • 2x gold-covered humbucker pickups in black mounting rings
  • 3-way toggle switch with black tip and gold nut
  • Gold adjustable bridge
  • 2x gold bridge posts with anchors
  • Gold trapeze tailpiece
  • 4x gold domed control knobs
  • Black archtop pickguard with gold mounting bracket
  • Set of strings
  • Assorted gold screws
  • Gold trim rings, hex nuts and washers
Prefer a figured top? The quilted maple veneer version with gold hardware uses the same body shape, and the mahogany hollow body with a Venetian cutaway comes with chrome hardware. Browse the full range of fully hollow body guitar kits.
Hollow Body Archtop Electric Guitar Kit, Mahogany Body, Gold Hardware, Ebonized Fretboard is on pre-order.
It has an adjustable bridge on two posts. A separate trapeze tailpiece holds the string ends at the bottom of the body.
