Red Pearloid Pickguard Single-Cutaway Electric Guitar Kit with Gold Hardware, Bound Maple Fretboard, Two Single-Coils
SKU TE-RMRG-5190
Original price $259.99 USD
Current price $219.99 USD
$219.99 USD - $219.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Nov 9 – Nov 23 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
A red pearloid pickguard and gold hardware on a classic single-cutaway body, with a bound maple fretboard. The red pearloid pickguard comes already fitted to the body with the gold-covered neck pickup mounted on it. Every metal part in the kit is gold: the six sealed tuners, the bridge plate and its six saddles, the control plate and both knobs, the neck pickup cover, the output jack plate, the strap buttons and the screws. An ivory binding strip runs along both edges of the maple fretboard, set off by black dot inlays.
The maple neck bolts on with four screws and carries 22 frets, black dot inlays, black side dots and a pointed 6-in-line headstock with a pre-slotted nut. Two single-coil pickups (a gold-covered neck pickup and a bridge pickup set in the gold bridge plate) run through 1 volume, 1 tone and a 3-way blade switch on the gold control plate. The body is plain wood with no veneer and no body binding, so it takes paint, stain or a clear finish directly.
  • The pickups and jack are soldered to the control plate's terminal board, so you need a soldering iron and some care with each joint
  • Six individual bridge saddles have to be set for string height and intonation during setup
  • Bolt-on neck, pre-cut cavities and a pickguard already fitted to the body keep the woodwork simple
  • Truss Rod: Two-Way, Adjustable (adjusted at the headstock)
  • Binding: Single Ivory (fretboard edges)
  • Side Dots: Black
  • Shape: Pointed, 6-in-line
  • Nut: Bone (pre-slotted)
  • Bridge: TE-Style Bridge (top-loading) (6 adjustable saddles)
  • Tuners: Sealed Diecast
  • Pickguard: Red Pearloid
  • Control Plate: Gold
  • Knobs: Gold Knurled Dome
  • Finish: Gold
  • 1x basswood body with single cutaway, routed for the neck pickup, bridge plate and control plate (unfinished)
  • 1x red pearloid pickguard fitted to the body, carrying a gold-covered single-coil neck pickup
  • 1x maple neck with bound maple fretboard, 22 frets, black dot inlays and a fitted nut (unfinished)
  • 1x gold bridge plate with a bridge single-coil pickup and 6 adjustable saddles
  • 1x gold control plate with 3-way blade switch, 2 gold knurled knobs and a wiring terminal board
  • 1x gold output jack plate with jack socket
  • 1x neck plate with 4 gold mounting screws
  • 1x instrument cable
Compare it with the basswood single-cutaway kit with a maple fretboard and the pre-wired mahogany single-cutaway kit, or browse the full range of single-cutaway guitar kits.
Red Pearloid Pickguard Single-Cutaway Electric Guitar Kit with Gold Hardware, Bound Maple Fretboard, Two Single-Coils is in stock.
What makes this single-cutaway kit different?
It pairs a red pearloid pickguard, fitted to the body with a gold-covered neck pickup already mounted on it, with gold hardware on every metal part: tuners, bridge plate and saddles, control plate, knobs, jack plate, strap buttons and screws. The maple fretboard is bound with an ivory strip along both edges and carries black dot inlays.
It has gold hardware and a red pearloid pickguard instead of chrome or black hardware and a solid-color pickguard. For a chrome-hardware maple-fretboard kit see the basswood single-cutaway kit; for no soldering at all see the pre-wired mahogany single-cutaway kit.
It scores 3/10, Beginner, on our build difficulty scale. The neck bolts on and every cavity is pre-cut; the steps that take care are soldering the two pickups and the jack to the control plate's terminal board and setting the six bridge saddles during setup.
This kit is right-handed only, with 6 strings, 22 frets and a 648 mm (25.5 inch) scale length.
