L2 Semi-Hollow Guitar Kit with Trapezoid Pearl White Inlays
SKU LPH-RAEB-1
Current price $279.99 USD
$279.99 USD - $279.99 USD
Build your own semi-hollow LP2 alder body DIY guitar with F-Holes.
  • Alder is a closed-grain wood, so no grain filling is needed before finishing
  • Material: Alder (2-3 pcs)
  • Type: Semi-Hollow Chambered
  • Center Block: None
  • Binding: Single Black
  • Material: Ebony
  • Binding: Single Ivory*
  • Tuners: Black Sealed
  • Unfinished semi-hollow body with two f-holes
  • Unfinished neck with bound dark fretboard and pearl trapezoid inlays
  • String set
  • 2x black-covered humbucker pickups in mounting rings
  • Pre-wired harness with four potentiometers, nuts and washers
  • 3-way toggle switch with nut and washer
  • Black square output jack plate with jack
  • Black stop tailpiece
  • Black bridge with individual saddles
  • 4x black bridge and tailpiece posts
  • 4x chrome dome control knobs
  • 2x black strap buttons with screws
  • Assorted black screws
Unfortunately, L2 Semi-Hollow Guitar Kit with Trapezoid Pearl White Inlays is out of stock.
