Double-Cutaway Contoured Electric Guitar Kit, Ash Body, Flame Maple Veneer, Humbucker + Two Single-Coils
SKU ST-RSBC-1
Current price $239.99 USD
$239.99 USD - $239.99 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Oct 6 – Oct 13 1–2 weeks from the date of your order. Ships to U.S. addresses only. Free Shipping
Ash body ST style guitar kit with Flame Maple Veneer, Maple Skunk Stripe Neck.
  • Material: Ash (2-3 pc)
  • Binding: Black
  • Top Veneer: Flame Maple
  • Scale Length: 648mm / 25.5″
  • Binding: Black
  • Pickguard: Pearl White
  • Knobs: White
  • Cavity Covers: White
  • Guitar neck with dark fretboard and white dot inlays
  • White pearl pickguard fitted with two white single-coil pickups, one white humbucker, three white skirted knobs and a blade switch with white tip
  • 6x chrome sealed tuners
  • 6x chrome tuner bushings
  • 6x chrome washers
  • Set of guitar strings
  • White translucent tremolo cavity cover plate
  • Chrome neck plate
  • Black neck plate gasket
  • 4x neck mounting screws
  • 3x tremolo springs
  • Chrome tremolo arm
  • 2x chrome strap buttons
  • 2x black-headed mounting screws
Double-Cutaway Contoured Electric Guitar Kit, Ash Body, Flame Maple Veneer, Humbucker + Two Single-Coils is in stock.
