SKU JG-RMRC-1
Original price $279.99 USD
Current price $229.99 USD
$229.99 USD - $229.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Sep 26 – Oct 10 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Intermediate (5/10)
  • Bridge: Tune-O-Matic
  • Tune-O-Matic bridge
  • White plastic nut
  • Red tortoise pickguard
  • 2x black control knobs
Short-scale JG style Guitar Kit with Mahogany Body, Rosewood Fretboard is in stock.
