SKU JG-RMRB-5103
Original price $279.99 USD
Current price $219.99 USD
$219.99 USD - $219.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Sep 4 – Sep 18 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Order options:: Free Shipping – International Warehouse
  • Orientation: Right-handed
Intermediate (5/10)
  • Material: Mahogany (2 pcs)
  • Radius: 12"
  • Shape: S-style 6-in-line
  • Tuner Holes: 10mm
  • Nut Width: 42mm
  • Bridge: Black Tune-O-Matic
  • Truss Rod: Double-action adjustable
  • Black Tune-O-Matic bridge
  • White plastic nut
  • 2x black control knobs
