Classic Single-Cutaway Electric Guitar Kit, Stripewood Body, Rosewood Fretboard, Black Hardware
SKU TE-RZFB-3600
Original price $259 USD
Current price $219 USD
$219 USD - $219 USD
Build your own Stripewood TE-style Guitar with Maple Neck and Rosewood Fretboard.
  • Straightforward wiring with few connections to solder, but the tremolo bridge requires careful setup for tuning stability
  • Binding: 3-ply black
  • Binding: Black
  • Binding: None (Product images show ivory single binding, but the actual kit does not include headstock binding.
  • Bridge: Hardtail
  • Tuners: Sealed
  • Pickguard: Pearl White
  • Body with striped dark and light grain, routed, with white pearl pickguard and neck pickup fitted
  • Maple neck with dark fretboard, frets and dot inlays
  • 6x black tuners with bushings, washers and screws
  • Black neck plate with four neck screws
  • Black control plate wired with two knobs, selector switch and output jack
  • Black square jack plate with output jack fitted
Classic Single-Cutaway Electric Guitar Kit, Stripewood Body, Rosewood Fretboard, Black Hardware is in stock.
It has a fixed bridge plate. The bridge pickup is mounted inside this plate. There is no tremolo arm.
