SKU TEH-RSAB-3689
Original price $279 USD
Current price $244 USD
$244 USD - $244 USD
  • Secure, encrypted checkout.
  • Material: Ash
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Binding: Single, Black
  • Bridge: Hardtail
  • 2x black dome knobs
  • 1x black barrel switch tip
  • 2x strap buttons
It has a fixed bridge plate with three saddles. The bridge pickup is mounted inside this plate. There is no tremolo arm.
Is the body hollow or solid?
Is the top solid spalted maple?
No. The top is a thin spalted maple veneer glued onto the body. Sand it lightly so you do not sand through it.
