Headless Electric Guitar Kit, Mahogany Body, Rosewood Fretboard, Abalone Inlays
SKU HL-RMRB-1
Original price $279.99 USD
$279.99 USD
$279.99 USD - $279.99 USD
Current price $279.99 USD
  • Material: Mahogany (1 pc)
  • Scale Length: 648mm, 25.5"
  • Number of Frets: 24
  • Inlay Material: Abalone
  • Shape: None
  • Nut: String Locking
  • Neck Pickup: Black Single Coil
  • Bridge Pickup: Black Humbucker
  • Controls: 1 Volume, 1 Tone, 5-Way Selector
  • Pickups: 2 Single Coil, 1 Humbucker
  • Bridge: Headless Tremolo
  • Tuners: Black Bridge-Mounted
  • Unfinished routed guitar body
  • Neck with fretted fingerboard, dot inlays and a black string clamp at the far end
  • Black headless bridge unit with six thumbwheel tuners
  • Black humbucker pickup
  • 2x black single coil pickups
  • Pre-wired harness with a blade selector switch and two potentiometers
  • 2x black dome knobs
  • Black switch tip
  • Output jack on a black square jack plate
  • Black cavity cover plate
  • 2x potentiometer nuts and 2x washers
  • 2x black springs
  • 4x black rubber grommets
  • 4x Allen wrenches
  • Black tremolo arm
Watch this kit get built, start to finish
Marty builds this exact kit in 23 short videos, from opening the box to setting the intonation. Every video sits at its step in the written manual, so you can read a step, watch it, then do it.
Unfortunately, Headless Electric Guitar Kit, Mahogany Body, Rosewood Fretboard, Abalone Inlays is out of stock.
Find the diagram for your kit
