SKU BLK-TL-L
Original price $249 USD
Current price $199 USD
$199 USD - $199 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Nov 16 – Nov 30 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Dexterity: Left-Handed
  • Bridge: Hardtail
  • 1x bag of assorted screws
  • 1x Allen wrench
