Basswood body JE-style guitar kit with Ebony fretboard Maple neck
SKU JE-RBEB-295
Current price $279.99 USD
$279.99 USD - $279.99 USD
Build your own DIY guitar using this Basswood body JE-style guitar kit with Ebony fretboard Maple neck.
  • Type: Solid with a Monkey Grip
  • Scale Length: 648mm, 25.5"
  • Material: Ebony
  • Number of Frets: 24
  • Nut: Black Locking Nut
  • Controls: 1 Volume, 1 Tone, 5-Way Selector
  • Wiring Diagram: HSH, 1 Volume, 1 Tone, 5-Way Switch
  • Bridge: Locking Tremolo
  • Basswood guitar body with double cutaway, upper-horn monkey grip cut-out and rear tremolo route (unfinished)
  • Maple neck with dark fretboard, pearl dot inlays and black locking nut fitted
  • Black pickguard pre-loaded with a neck humbucker, a middle single-coil and a bridge humbucker, a 5-way blade switch and two black knurled knobs marked VOLUME and TONE
  • Black double-locking tremolo bridge with tremolo arm
  • 3x tremolo springs with chrome spring claw and two long mounting screws
  • Black rear tremolo cavity cover plate
  • Black angular truss rod cover with screws
  • Black rounded-square jack plate with output jack socket
  • 2x black strap buttons with black felt washers and screws
  • Coiled string set
  • Assorted black screws
Basswood body JE-style guitar kit with Ebony fretboard Maple neck is on pre-order.
humbucker, single-coil, humbucker, 1 volume, 1 tone, 5-way switch
