Mahogany JBM-style Guitar Kit with Rosewood Fretboard
SKU JBM-RMFB-3411
$299 USD
$299 USD - $299 USD
Current price $299 USD
Build your own 6-string Mahogany Body JBM-style Guitar Kit with Rosewood Fretboard and Mahogany Neck.
  • Scale Length: 673 mm / 26.5"
  • Number of Frets: 24
  • Nut: Black Locking Nut
  • Bridge: Locking Tremolo
  • Tuners: Sealed
  • Body with figured light top, routed for two humbuckers, a single-coil and the tremolo
  • Neck with dark fretboard, frets, block inlays and a black locking nut fitted
  • 6x black tuners with bushings
  • 2x black humbucker pickups with mounting rings removed
  • Black double-locking tremolo bridge
  • Tremolo arm
  • Spring claw with three springs
  • String retainer bar
  • Wiring harness with pots, selector switch and one black dome knob
  • Black tremolo cavity cover with a string slot
  • 2x round black cavity covers
  • Black oval jack plate with output jack fitted
  • Black truss rod cover
  • Assorted mounting screws, washers and grommets
  • 3x Allen wrenches
  • Coiled set of strings
Mahogany JBM-style Guitar Kit with Rosewood Fretboard is in stock.
It has a locking tremolo with an arm. The strings clamp down at the bridge and at a locking nut at the top of the neck.
