Skunk-Stripe Neck Offset Electric Guitar Kit with Bound Rosewood Fretboard, Mahogany Body, Rhythm and Lead Circuit
SKU JG-RMRC-5231
Original price $289 USD
Current price $259 USD
$259 USD - $259 USD
Pre-order now and your kit ships free from our U.S. warehouse in about 3 months. Nothing extra to pay at delivery.
  • Secure, encrypted checkout.
A skunk-stripe maple neck with a bound rosewood fretboard, on a solid mahogany offset body. The skunk stripe is the dark strip down the back of the neck. It covers the slot for the truss rod, so the fretboard face stays one clean piece. Ivory binding runs along both edges of the fretboard, with the side dots set into it. The frets are in and the headstock is drilled.
The ivory pickguard holds the full rhythm and lead circuit. The slide switch, the 3-way toggle and the rhythm controls are already mounted. You solder in the two P90 pickups. The 24 in (610 mm) scale is shorter than a 25.5 in neck, so the frets sit closer together. There are 21 stainless-steel frets with dot inlays. A six-saddle bridge pairs with a chrome floating vibrato. The tuners are sealed and the hardware is chrome. The mahogany body has no veneer, so it is ready for any stain, paint or clear coat.
  • The floating vibrato tailpiece needs careful setup so the guitar stays in tune
  • The flat slab body is straightforward to sand, and every cavity and hole is pre-cut
  • Material: Maple with Skunk Stripe
  • Scale Length: 610 mm / 24"
  • Binding: Single, Ivory
  • Tuner Layout: 6-in-line
  • Pickguard: Ivory
  • 1x unfinished solid mahogany offset body
  • 1x skunk-stripe maple neck with bound rosewood fretboard (frets installed), dot inlays and a drilled headstock
  • 1x ivory pickguard with slide switch, toggle switch and rhythm circuit pre-installed
  • 2x ivory P90 pickups with exposed pole pieces
  • 1x chrome control plate
  • 1x chrome floating vibrato tailpiece with arm
  • 2x chrome control knobs
  • 2x springs
  • 2x black strap buttons
  • 2 bags of assorted screws and small parts
Compare it with the block-inlay mahogany offset kit with a tortoise pickguard or the dual-humbucker mahogany offset kit, or browse the full range of offset guitar kits.
Skunk-Stripe Neck Offset Electric Guitar Kit with Bound Rosewood Fretboard, Mahogany Body, Rhythm and Lead Circuit is on pre-order.
Find the diagram for your kit
What is a skunk stripe on a guitar neck?
It is the darker strip of wood running down the back of the maple neck. It fills the channel the truss rod was fitted through from behind, which lets the fretboard face stay one clean piece. On this kit the neck also has ivory binding along both edges of the rosewood fretboard.
What does the rhythm and lead circuit do?
The slide switch on the pickguard flips between two preset sounds. The lead circuit uses the main volume, tone and 3-way toggle; the rhythm circuit has its own volume and tone for the neck pickup. Every connection is shown in the offset rhythm and lead wiring diagram.
It is rated Intermediate, 5 out of 10, on our build difficulty score. The floating vibrato needs careful setup, and the open-grain mahogany needs grain filler before finishing; every cavity and hole is pre-cut.
What is the scale length?
24 in (610 mm), shorter than the common 25.5 in scale, so the reach between frets is shorter. It has 21 stainless-steel frets on a 14 in radius rosewood fretboard.
