Semi-Hollow ST style guitar kit w/ Alder body, Stripewood Body Top
SKU STH-RAOC-1
Original price $279 USD
Current price $249 USD
$249 USD - $249 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Dec 25 – Jan 8 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Build a beautiful semi-hollow body ST style DIY guitar with Alder wood body and Stripewood body top.
Stripewood is our name for this wood veneer. The factory dyes cottonwood, a type of poplar, then glues and presses it in layers with heat and pressure so it looks striped. No resin is used. Here it is sliced into a thin top. Other shops sell it as engineered zebrawood. Want to stain or oil it? Test on a hidden spot first.
  • Stripewood veneer is thin and easy to sand through, so use a light touch at the edges
  • Material: Alder (2-3 pc)
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Top: Stripewood veneer (reconstituted wood, thin sheet)
  • Cavity Covers: Chrome Metal
  • Guitar body with striped veneer (unfinished), f-hole and open pickup and control routes
  • Guitar neck with dark fretboard and white dot inlays
  • 6x chrome sealed tuners
  • 6x chrome tuner bushings
  • 6x washers
  • Set of guitar strings
  • 2x black humbucker pickups with exposed pole pieces
  • Chrome neck plate with four long mounting screws
  • Chrome rounded-end cavity cover plate
  • 2x chrome dome knobs
Semi-Hollow ST style guitar kit w/ Alder body, Stripewood Body Top is in stock.
Find the diagram for your kit
Is the body hollow or solid?
