Devil-Horn Double-Cutaway Electric Guitar Kit, Mahogany Body, Bolt-On Neck, Rosewood Fretboard, Pre-Wired Dual Humbuckers
SKU DVH1-RMRC-512
Original price $249.99 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Nov 13 – Nov 27 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
Devil-Horn guitar kit featuring a mahogany body with a symmetric double-cutaway design, a mahogany neck, and a rosewood fretboard with trapezoid inlays. This kit includes pre-wired electronics with 2 humbuckers and a complete wiring harness - no soldering required.
  • Bolt-on neck joint requires only a screwdriver for attachment
  • Pre-wired electronics eliminate all soldering - just plug in the pickups and connect
  • Tailpiece: Stop Bar
  • Knobs: Black Speed Knobs
  • Pre-wired electronics harness (2 humbucker pickups, 2 volume pots, 2 tone pots, 3-way toggle switch, output jack - all wired and ready to install)
  • Adjustable bridge
  • Stop bar tailpiece
  • 4x black speed knobs
  • 2x black cavity covers
  • Neck plate and screws
Devil-Horn Double-Cutaway Electric Guitar Kit, Mahogany Body, Bolt-On Neck, Rosewood Fretboard, Pre-Wired Dual Humbuckers is in stock.
