SKU ST-RZZC-1
Original price $259.99 USD
Current price $196.99 USD
$196.99 USD - $196.99 USD
The body, neck and fretboard are all Stripewood, so the bold dark-and-light stripe runs through the whole guitar. Stripewood is our name for this wood. The factory dyes thin sheets of wood, glues them into a block, and shapes it. You can see the layers on the body edges, the back and the sides of the neck. Other shops sell it as engineered zebrawood. Want to stain or oil it? Test inside a cavity first.
  • Knobs: White
  • Cavity Covers: White
  • Neck plate with screws
  • Output jack with wiring
  • String trees
What is Stripewood?
Stripewood is our name for this wood. The factory dyes thin sheets of wood, glues them into a block, and shapes it. So the stripes run all the way through the body, neck and fretboard, not only on top. Other shops sell it as engineered zebrawood.
