Devil-Horn Double-Cutaway Electric Guitar Kit, Mahogany Body, Set-In Neck, Rosewood Fretboard, Dual Humbuckers
SKU DVH1-RMRC-1
$289.99 USD
$289.99 USD - $289.99 USD
Current price $289.99 USD
Devil-Horn guitar kit featuring a mahogany body with a symmetric double-cutaway design, a set-in mahogany neck, and a rosewood fretboard with white pearloid trapezoid inlays. Standard 24 3/4" scale with 22 frets, two humbuckers, a adjustable bridge with stopbar tailpiece, and chrome hardware throughout.
  • The set-in neck joint is fixed, so string height and intonation are dialled in at the bridge and nut rather than by shimming
  • Material: Mahogany (2-4 piece)
  • Shape: Wave 3+3
  • 2x humbucker pickups
  • 6x sealed tuning machines
Devil-Horn Double-Cutaway Electric Guitar Kit, Mahogany Body, Set-In Neck, Rosewood Fretboard, Dual Humbuckers is on pre-order.
