SKU TEH-RSAB-3689
Original price $279.99 USD
Current price $244.99 USD
$244.99 USD - $244.99 USD
  • Material: Ash
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Binding: Single, Black
  • Top Veneer: Spalted Maple
  • Scale Length: 648 mm / 25.5″
  • Bridge: Hardtail
  • Neck with fretted fingerboard, dot position markers and a drilled headstock
  • 2x black dome knobs
  • 1x black barrel switch tip
  • 2x strap buttons
