SKU TEH-RSAB-3689
Original price $279 USD
Current price $244 USD
$244 USD - $244 USD
  • Material: Ash
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Binding: Single, Black
  • Bridge: Hardtail
  • 2x black dome knobs
  • 1x black barrel switch tip
  • 2x strap buttons
