Headless Electric Guitar Kit, Quilted Maple Veneer, Mahogany Body, Ebonized Fretboard
SKU HL-RPPB-1
$299 USD
$299 USD - $299 USD
Current price $299 USD
A headless HSS kit with a quilted maple veneer top on a mahogany body, a tremolo bridge and an ebonized fretboard with trapezoid inlays. Every cavity is pre-routed for one humbucker and two single coils, so you sand, finish, wire and play.
  • Number of Frets: 24
  • Shape: None
  • Tuner Hole Diameter: Not applicable (headless)
  • Nut: String Locking
  • Controls: 1 Volume, 1 Tone, 5-Way Selector
  • Pickups: 1 Humbucker, 2 Single Coils
  • Bridge: Headless Tremolo
  • Tuners: Bridge-mounted (headless)
  • Unfinished routed guitar body
  • Neck with fretboard (frets installed), trapezoid white pearloid inlays and a black string clamp at the far end
  • Black headless bridge unit with six thumbwheel tuners
  • 3x black covered pickups (1 humbucker, 2 single coils)
  • 5-way switch with two potentiometers and wiring loom
  • Output jack on a black square jack plate
  • 2x black knobs
  • Black oval cavity cover plate
  • Neck plate with screws
  • 2x potentiometer nuts and 2x washers
  • 1x spring
  • 4x Allen wrenches
  • Black tremolo arm
  • 2x black strap buttons with washers
New to headless builds?
We filmed a complete headless build, 23 short videos from unboxing to final setup. It is shot on our mahogany body HSS kit rather than this one, so your hardware and pickup layout may differ, but the headless parts that trip people up are the same: how the bridge tunes, how the neck-end clamp holds the string, and the order you string it in.
Headless Electric Guitar Kit, Quilted Maple Veneer, Mahogany Body, Ebonized Fretboard is on pre-order.
Find the diagram for your kit
Where are the tuners?
It is a headless guitar, so there is no headstock. You tune the strings with knobs on the bridge.
