Three Humbucker Single-Cutaway Electric Guitar Kit with Vibrato Tailpiece, Mahogany Body, Bound Maple Fretboard, Abalone Pearloid Trapezoid Inlays
SKU LP-RMSC-5631
Original price $279 USD
Current price $249 USD
$249 USD - $249 USD
Three humbuckers and a vibrato tailpiece set this single-cutaway kit apart: three ivory-ringed humbuckers fill the mahogany body, and a chrome vibrato tailpiece with an adjustable bridge lets you add gentle pitch bends and shimmer. The maple neck carries a bound maple fretboard with Abalone Pearloid trapezoid inlays, so the light board and the shell-look inlays stand out against the mahogany.
Underneath it is a set-neck single-cutaway build: a multi-piece mahogany body with no veneer, a maple neck that glues into a long neck pocket, a bone nut, chrome hardware, gold knobs, and an ivory pickguard and cavity covers to match the pickup rings.
  • The fretboard binding should be masked or scraped clean after staining so the ivory edge stays crisp
  • Profile: C-shaped (flat C)
  • Side Dots: Black
  • Shape: Classic Blues, 3+3
  • Nut: Bone (pre-installed)
  • Middle Pickup: Humbucker (chrome cover, ivory ring)
  • Pickguard: Ivory
  • Knobs: Gold bell
  • Cavity Covers: Ivory
  • Truss Rod Cover: Black
  • 1x unfinished mahogany single-cutaway body, routed for three humbuckers
  • 1x maple set neck with bound maple fretboard, Abalone Pearloid trapezoid inlays and pre-installed bone nut
  • 3x chrome-covered humbuckers in ivory mounting rings
  • 1x control harness with potentiometers and hookup wire
  • 4x gold bell knobs with nuts and washers
  • 1x chrome vibrato tailpiece with arm
  • 1x ivory control cavity cover
  • 1x black truss rod cover
  • 1x bag of assorted screws
  • 1x Allen wrench
  • 1x guitar cable
Browse the full range of single-cutaway guitar kits, or compare the mahogany kit with a maple fretboard and pre-wired electronics and the bound-neck kit with Vinework inlay.
Three Humbucker Single-Cutaway Electric Guitar Kit with Vibrato Tailpiece, Mahogany Body, Bound Maple Fretboard, Abalone Pearloid Trapezoid Inlays is on pre-order.
Find the diagram for your kit
What does the vibrato tailpiece do?
It lets you bend the pitch of all six strings slightly with the arm, for gentle vibrato and shimmer on chords and held notes. It works with the included adjustable bridge, and the strings anchor at the tailpiece rather than through the body.
How are the three humbuckers controlled?
The kit has four knobs and a three-way toggle switch, with an ivory-ringed humbucker in the neck, middle and bridge positions. You solder the wiring yourself, so you can choose how the middle pickup is wired.
What are the inlays made of?
They are Abalone Pearloid, a man-made material that looks like abalone shell. The trapezoid inlays are set into the maple fretboard at the factory, so there is nothing to install.
It is rated Intermediate, 7 out of 10. The neck is glued in, the mahogany needs grain filling, and the fretboard binding should be masked or scraped after staining. See how we score every kit in our build difficulty guide.
