Diamond Inlay Single-Cutaway Electric Guitar Kit with Black Hardware, Mahogany Body, Ebonized Fretboard, Humbuckers
SKU LP-RMMB-5453
$229 USD
$229 USD - $229 USD
Current price $229 USD
White Pearloid diamond inlays sit in a black ebonized fretboard on this single-cutaway kit, and every piece of hardware is black to match. The tuners, bridge, tailpiece, humbucker rings, knobs, jack plate, nut, pickguard and cavity covers all come in black, so the kit already has a consistent dark trim before you choose a finish for the wood.
Underneath it is a set-neck single-cutaway build: a two-piece mahogany body with no veneer and a single black binding around the top edge, a mahogany neck that glues into a long neck pocket, 22 stainless steel frets, two black humbuckers, and an adjustable bridge with a stopbar tailpiece.
  • The black body binding should be masked or scraped clean after staining so the edge stays crisp
  • Material: Mahogany (2 pieces, center joint)
  • Inlay Shape: Diamond
  • Side Dots: White
  • Shape: Classic Blues, 3+3
  • Nut: Black Plastic (pre-installed)
  • Neck Pickup: Humbucker (black, black ring)
  • Bridge Pickup: Humbucker (black, black ring)
  • Knobs: Black top hat
  • Truss Rod Cover: Black
  • 1x unfinished two-piece mahogany single-cutaway body with single black binding, routed for two humbuckers
  • 1x mahogany set neck with ebonized fretboard, White Pearloid diamond inlays and pre-installed black nut
  • 6x black sealed tuners with bushings, washers and screws
  • 2x black humbuckers in black mounting rings
  • 1x three-way toggle switch with a Rhythm/Treble ring
  • 4x black top hat knobs with nuts and washers
  • 1x black adjustable bridge with 2 posts
  • 1x black stopbar tailpiece with 2 studs
  • 1x black pickguard with mounting bracket
  • 1x large black control cavity cover
  • 1x round black switch cavity cover
  • 1x black truss rod cover
  • 2x black strap buttons
  • 1x bag of assorted screws
  • 1x guitar cable
Browse the full range of single-cutaway guitar kits, or compare the mahogany kit with an ebonized fretboard and chrome hardware and the bound neck and headstock kit with Vinework inlay.
Diamond Inlay Single-Cutaway Electric Guitar Kit with Black Hardware, Mahogany Body, Ebonized Fretboard, Humbuckers is in stock.
What are the diamond inlays made of?
They are White Pearloid, a man-made material that looks like pearl shell. The diamonds are set into the ebonized fretboard at the factory, so there is nothing to install.
No. It is ebonized wood, which is wood colored black to look like ebony.
It pairs White Pearloid diamond inlays with black hardware, a black nut and black binding. The mahogany kit with an ebonized fretboard uses chrome hardware, and the bound neck and headstock kit has a rosewood fretboard with a Vinework inlay.
It is rated Intermediate, 7 out of 10. The neck is glued in, the mahogany needs grain filling, and the black binding should be masked or scraped after staining. See how we score every kit in our build difficulty guide.
