SKU BLK-TL-A
Original price $249 USD
Current price $199 USD
$199 USD - $199 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Dec 2 – Dec 16 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
  • Bridge: Hardtail
What is a blank kit?
The body is a solid block of wood, and you cut the outline yourself. These are already cut: the neck pocket, the bridge pickup cavity and the control slot. The six tuner holes in the headstock are already drilled.
