Heavy Metal Electric Guitar Kit, Basswood Body, Flame Maple Veneer, Ebonized Fretboard, Bolt-On Neck
SKU DB-RMEB-437
Current price $259.99 USD
$259.99 USD - $259.99 USD
A flamed maple top on our Heavy Metal body with a clean face: no pickguard, and a toggle switch fitted from the back so only its tip shows. Basswood body, maple neck and a clean ebonized fretboard with no inlays, built to order for builders who want a figured top on an aggressive shape.
  • Inlay Shape: None
  • Shape: Fork Tail, 3+3
  • Nut: Black Locking Nut
  • Middle Pickup: None
  • Bridge: Locking Tremolo
  • Strings: Steel Machine
  • Basswood body with a flamed maple veneer top, unfinished, routed for two humbuckers and a recessed tremolo, controls routed from the back
  • Maple neck with ebonized fretboard, frets, no inlays and a black locking nut fitted
  • Black tremolo arm
  • 3x black dome knobs
  • 2x black strap buttons
  • 3x Allen wrenches
Heavy Metal Electric Guitar Kit, Basswood Body, Flame Maple Veneer, Ebonized Fretboard, Bolt-On Neck is on pre-order.
How long does this kit take to arrive?
This kit is built to order in a new batch. Plan on about 4 to 6 months before it ships. We will email you when your kit is on its way.
How thick is the flame maple top?
It is a flamed maple veneer, a thin sheet about 0.5 mm thick glued over the basswood body. Sand it lightly so you do not cut through it.
Does the fretboard have inlays?
No. The ebonized fretboard is left plain, with no inlays on its face.
