Blank Electric Guitar Kit, Basswood Body, Maple Neck, Maple Fretboard
SKU BLK-ST-C
Original price $229 USD
Current price $199 USD
$199 USD - $199 USD
  • Secure, encrypted checkout.
A blank basswood body you cut to your own outline, paired with an assembled maple neck and a maple fretboard. The body ships as an uncut rectangular basswood slab, so you draw and cut the shape yourself. Basswood is light, soft and closed-grained, so it cuts and sands easily with hand tools and needs no grain filling before paint. The cavities are already done: neck pocket, the three pickup rout under the pickguard, the control area, the output jack recess and the tremolo spring cavity. The maple neck arrives complete, with a maple fretboard, frets, black dot inlays, a fitted nut and a shaped headstock whose six tuner holes are already drilled. You bring the saw, the sandpaper and the soldering iron.
Prefer a darker wood? The same blank is also available with a mahogany body and mahogany neck. See every kit you shape yourself in our blank DIY guitar kits collection.
  • The output jack recess is already routed, so keep it inside the outline you draw
  • Basswood is soft and closed-grained: no grain filling is needed, but the cut edges dent easily, so handle the body with care
  • Controls: 1 Volume, 2 Tone
  • Unfinished rectangular basswood body blank, 36 x 48 cm and 4.4 cm thick, outline not cut, with the neck pocket, pickup, control, output jack and tremolo spring routs already cut
  • Maple neck with maple fretboard, frets, black dot position markers, fitted nut and a shaped headstock with six tuner holes drilled
  • 1x chrome neck plate
  • 4x neck mounting screws
  • 1x tremolo arm
  • 1x boat-style jack plate with output jack
  • 2x strap buttons
You will cut the body outline and solder the electronics. Depending on the finish you choose, the tools below cover a standard build.
  • For shaping the body: Bandsaw or jigsaw, rasps or spokeshave, sanding blocks
  • For finishing: Sandpaper (220-600 grit), sanding sealer, primer, paint or stain, clear coat
Woodworking required. You cut the body outline from a rectangular blank yourself. The neck pocket, pickup and control cavities, the output jack recess and the wiring channel are already routed, the headstock is already shaped and drilled, and the electronics need soldering.
Blank Electric Guitar Kit, Basswood Body, Maple Neck, Maple Fretboard is in stock.
Is the fretboard maple?
Yes. Both the neck and the fretboard are maple, with black dot position markers.
Do I need grain filler on the basswood body?
No. Basswood is a closed-grain wood, so it sands smooth without grain filler. It is soft, so handle the cut body carefully to avoid dents before you seal it.
Does the neck come assembled?
Yes. The maple neck arrives with the maple fretboard, frets, black dot inlays and nut already fitted, and the headstock shaped with its six tuner holes drilled.
