SKU BLK-ST-A
Original price $229 USD
Current price $199 USD
$199 USD - $199 USD
  • Secure, encrypted checkout.
  • Controls: 1 Volume, 2 Tone
  • 1x chrome neck plate
  • 4x neck mounting screws
  • 1x tremolo arm
  • 2x strap buttons
What is a blank kit?
The body is a solid block of wood, and you cut the outline yourself. The neck pocket and the tremolo route are already cut. The six tuner holes in the headstock are already drilled.
