SKU ST-RZZC-1
Original price $259 USD
Current price $195 USD
$195 USD - $195 USD
USA (Domestic) Our U.S. warehouse ships to domestic addresses across all 50 states only. In Stock Est. Delivery: Nov 16 – Nov 23 3–8 business days from the date of your order. Can take a little longer around holidays. Ships to U.S. addresses only. Free Shipping
  • Secure, encrypted checkout.
The body, neck and fretboard are all Stripewood, so the bold dark-and-light stripe runs through the whole guitar. Stripewood is our name for this wood. The factory dyes cottonwood, a type of poplar, then glues and presses it in layers with heat and pressure so it looks striped. No resin is used. You can see the layers on the body edges, the back and the sides of the neck. Other shops sell it as engineered zebrawood. Want to stain or oil it? Test inside a cavity first.
  • Knobs: White
  • Cavity Covers: White
  • Neck plate with screws
  • Output jack with wiring
  • String trees
What is Stripewood?
Stripewood is our name for this wood. It is not the zebrawood tree. The factory dyes cottonwood, a type of poplar, then glues and presses it in layers with heat and pressure so it looks striped. No resin is used. So the stripes run all the way through the body, neck and fretboard, not only on top. Other shops sell it as engineered zebrawood.
