Spalted Maple Thin Semi-Hollow Single-Cutaway Electric Guitar Kit with Two Humbuckers, Ash Body, Maple Fretboard
SKU TEH-RSAB-2
Original price $289 USD
Current price $259 USD
$259 USD - $259 USD
A spalted maple top and two humbuckers on a thin semi-hollow ash body. Spalted maple is pale maple marked with dark natural lines, and every sheet is different, so no two of these tops look alike. The veneer is glued to the top of a chambered ash body with one f-hole and a black binding line around the top edge. Two chrome-covered humbuckers sit in a large white pearl pickguard, in place of the two single-coils on our two single-coil spalted maple semi-hollow kit.
Around that body: a bolt-on maple neck with a maple fretboard and black dot inlays, 21 frets with rounded fret ends, a chrome six-saddle hardtail bridge with the strings loaded through the back of the body, chrome sealed tuners and a pre-assembled volume, tone and 3-way blade switch harness.
  • Spalted maple veneer is thin and easy to sand through, so use a light touch at the edges and around the f-hole
  • Two humbuckers mean more solder joints than a single-pickup kit, but the pots, switch and jack come pre-assembled
  • Hardtail bridge has no tremolo to set up, and the headstock is already shaped with its tuner holes drilled
  • Material: Ash
  • Type: Semi-Hollow Chambered
  • Sound Holes: 1 f-hole
  • Top: Spalted Maple
  • Joint: Bolt-on (4 screws and neck plate)
  • Truss Rod: Two-Way, Adjustable(adjusted at the headstock end)
  • Radius:Ā 14" / 356 mm
  • Fret Ends: Rounded
  • Side Dots: Yes
  • Neck Pickup: Humbucker, chrome cover
  • Bridge Pickup: Humbucker, chrome cover
  • Bridge: Hardtail, 6 saddles, string-through body
  • Tuners: Sealed
  • Pickguard: White Pearl
  • Knobs: Chrome dome
  • 1x unfinished semi-hollow ash body with spalted maple veneer top, one f-hole and black top binding
  • 1x white pearl pickguard with two chrome-covered humbuckers mounted
  • 1x maple neck with maple fretboard, 21 frets, black dot inlays and a drilled headstock
  • 1x chrome six-saddle hardtail bridge
  • 6x string ferrules for the back of the body
  • 1x pre-assembled control harness with volume and tone pots, 3-way blade switch and output jack
  • 2x chrome dome knobs
  • 1x black switch tip
  • 1x chrome jack plate
  • 1x chrome neck plate with four neck screws
  • 2x strap buttons
  • 1x guitar cable
Browse the full range of semi-hollow single-cutaway guitar kits and spalted maple guitar kits.
Spalted Maple Thin Semi-Hollow Single-Cutaway Electric Guitar Kit with Two Humbuckers, Ash Body, Maple Fretboard is in stock.
What is spalted maple?
Spalted maple is maple marked with dark lines left by natural fungus in the wood before it was dried. On this kit it is a thin veneer glued over the top of the ash body, so every top has its own pattern.
How is it different from your other semi-hollow single-cutaway kits?
It pairs the spalted maple top with two humbuckers and a white pearl pickguard. Our spalted maple semi-hollow kit with two single-coils has the same top with a different pickup layout, and the ash semi-hollow kit with a zebrawood look veneer has two humbuckers under a different top.
How hard is it to build?
It is rated Intermediate, 6 out of 10. The thin spalted maple veneer needs a light touch when sanding, the open-grain ash wants grain filler before finishing, and the two humbuckers have to be soldered to the pre-assembled harness. See how we score build difficulty.
What scale length and how many frets does it have?
The bolt-on maple neck has a 25.5 inch (648 mm) scale, a maple fretboard and 21 frets with rounded fret ends. It is a right-handed, full-size six-string.
