SKU BLK-TL-L
Original price $249 USD
Current price $199 USD
$199 USD - $199 USD
  • Secure, encrypted checkout.
  • Dexterity: Left-Handed
  • Bridge: Hardtail
  • 1x bag of assorted screws
  • 1x Allen wrench
What is a blank kit?
The body is a solid block of wood, and you cut the outline yourself. The neck pocket, the pickup routes and the control slot are already cut. The six tuner holes in the headstock are already drilled.
Is this kit left-handed?
