Blank Junior Guitar Kit with Mahogany Body and Rosewood Fretboard
SKU BLK-LPJ-A
$249.99 USD
$249.99 USD - $249.99 USD
Current price $249.99 USD
Build a guitar with soul and character using our Junior LP-style Blank Guitar Kit. Designed for DIY builders who want creative freedom, this slab-body mahogany kit comes with a blank headstock and an unfinished surface so you can carve, sand, paint, and finish it exactly the way you imagine. Classic Junior tone meets complete customization control.
  • Shape: Blank (Not Drilled)
  • Neck Pickup: None
  • Pickguard: Ivory
  • Rectangular mahogany body blank, uncut, with a neck pocket, one pickup route, control holes and a rear control cavity
  • Neck with dark fretboard, frets, pearl block inlays and an uncut paddle headstock
  • Black covered humbucker pickup with black mounting ring
  • Wiring harness with pot and coloured wiring
  • Tune-o-matic bridge with six saddles
  • Chrome stop bar tailpiece
  • 2x black dome knobs
  • Ivory pickguard
  • Black truss rod cover
  • Black neck plate with four neck screws
  • 2x strap buttons
  • Coiled set of strings
Blank Junior Guitar Kit with Mahogany Body and Rosewood Fretboard is on pre-order.
1 humbucker, 1 volume, 1 tone
