Blank Junior Guitar Kit, Mahogany Body, Rosewood Fretboard
SKU BLK-LPJ-B
Original price $259 USD
Current price $199 USD
$199 USD - $199 USD
  • Secure, encrypted checkout.
Build your own Junior LP-style guitar from the first cut to the final polish. This blank-body DIY kit is made for builders who want full creative control, with an unshaped headstock and unfinished mahogany body ready for cutting, shaping, sanding, staining, or painting. A true hands-on project for anyone who wants to design their own tone machine instead of buying one off the shelf.
  • You cut the body outline yourself from a flat rectangular blank, the biggest woodworking step in this build
  • Top: None
  • Neck Pickup: None
  • Neck with dark fretboard, dot position markers and an undrilled paddle headstock
  • 2x chrome dome knobs
  • 1x chrome stop tailpiece
  • Chrome nuts and washers
  • 1x chrome neck plate
  • 4x neck mounting screws
  • 1x black pickguard
  • 2x black strap buttons
  • 1x Allen wrench
Blank Junior Guitar Kit, Mahogany Body, Rosewood Fretboard is in stock.
1 humbucker, 1 volume, 1 tone
What is a blank kit?
The body is a solid slab of wood, and you cut the outline yourself. These are already cut: the neck pocket, one pickup route, the bridge holes and the control holes. The headstock is a plain paddle with no tuner holes, so you drill them where you want them.
