Bolt-On Maple Neck Single-Cutaway Electric Guitar Kit with Black Hardware, Mahogany Body, Rosewood Fretboard, Humbuckers
SKU LP-RMMB-5720
Original price $259 USD
Current price $229 USD
$229 USD - $229 USD
International (Worldwide) Our international fulfillment hub ships worldwide to over 100 countries. In Stock Est. Delivery: Dec 22 – Jan 5 4–6 weeks from the date of your order. Ships to 100+ countries. Free Shipping
A bolt-on maple neck with a rosewood fretboard sits on a mahogany single-cutaway body in this kit, and every piece of hardware is black. The neck fastens to the body with four screws and a black neck plate, so you can fit it, check the alignment and take it off again before any glue or finish is involved. The tuners, bridge, tailpiece, humbuckers, knobs, pickguard and cavity covers all come in black.
The fretboard carries White Pearloid trapezoid inlays and a pre-installed bone nut, 44.5 mm wide. The body is two to three pieces of mahogany with no veneer and no binding, routed for two humbuckers, with an adjustable bridge and a stopbar tailpiece. The factory notes that the real wood is a little darker than it looks in these photos.
  • The bolt-on neck attaches with four screws, so there is no glue-up and the neck can be removed for finishing
  • Material: Mahogany (2-3 pieces)
  • Side Dots: White
  • Shape: Styled, 3+3
  • Nut: Bone (pre-installed)
  • Nut Width: 44.5 mm
  • Neck Pickup: Humbucker (black)
  • Bridge Pickup: Humbucker (black)
  • Truss Rod Cover: Black
  • 1x unfinished mahogany single-cutaway body, routed for two humbuckers and a bolt-on neck
  • 1x bolt-on maple neck with rosewood fretboard, White Pearloid trapezoid inlays and pre-installed bone nut
  • 1x black neck plate with mounting screws
  • 6x black sealed tuners with bushings, washers and screws
  • 2x black humbuckers
  • 1x three-way toggle switch with a Rhythm/Treble ring
  • 4x black knobs
  • 1x black adjustable bridge with 2 posts
  • 1x black stopbar tailpiece with 2 studs
  • 1x black pickguard with mounting bracket
  • 1x large black control cavity cover
  • 1x round black switch cavity cover
  • 1x black truss rod cover
  • 2x black strap buttons
  • 1x bag of assorted screws
  • 1x Allen wrench
  • 1x guitar cable
Browse the full range of single-cutaway guitar kits, or compare the diamond inlay kit with black hardware and a set neck and the bolt-on kit with pre-wired electronics.
Bolt-On Maple Neck Single-Cutaway Electric Guitar Kit with Black Hardware, Mahogany Body, Rosewood Fretboard, Humbuckers is in stock.
Is the neck glued in?
No. It is a bolt-on neck. It fastens to the body with four screws through a black neck plate, so you can fit it, check the alignment and remove it again to finish the body and neck separately.
What are the trapezoid inlays made of?
They are White Pearloid, a man-made material that looks like pearl shell. The trapezoids are set into the rosewood fretboard at the factory, so there is nothing to install.
What is the nut made of?
The nut is bone, pre-installed at the factory, and 44.5 mm (1.75") wide.
Will my kit look exactly like the photos?
The parts and hardware are the same, but the factory notes that the real mahogany and maple are a little darker than they look in the photos. Every piece of wood also has its own grain.
It is rated Beginner, 4 out of 10. The neck bolts on, every route and hole is pre-cut, and the mahogany needs grain filling before the finish. See how we score every kit in our build difficulty guide.
